ground
Old Sep 14, 2009 | 09:13 AM
firestang's Avatar
ground
where have you guys ground out your amps when placing them in the trunk. i don't think my amp is grounded sufficiently, and thought someone might have a better suggestion.
thanks
Old Sep 14, 2009 | 09:16 AM
05GT-O.C.D.'s Avatar
I lust for a M24
Grounded mine on the package try by inserting a nut/bolt through an existing hole after sanding the metal for a good contact.
Old Sep 14, 2009 | 12:52 PM
houtex's Avatar
"...after sanding the metal for a good contact."
This. Just screwin' it onto metal somewhere is not nearly enough.
Old Sep 14, 2009 | 01:28 PM
NotQuik's Avatar
I haven't messed with the mustang radio at all but where do they ground the factory amps and how are they terminated? Maybe you could ground i the same general location. Regardless make sure you get ride of the paint between the lug and whatever your grounding to for a better connection as mentioned.
Old Sep 14, 2009 | 06:32 PM
tdbrown75's Avatar
Bolted mine under the "Latch" bar, underneath the back seats. Uses a T60 like a seat belt does. Just bolt it under there "after sanding the metal for a good contact". I've done three 'Stang sound systems with various amps and all are nice and clean sounding.
Tim
Old Sep 18, 2009 | 09:16 PM
gremlin190's Avatar
Firestang,
Everything said above, but why do you not think your amp is grounded properly?
Old Sep 19, 2009 | 03:08 PM
NotQuik's Avatar
if you have any questions I would be happy to check it out with you...pm me for my number.
samjluck
Oct 26, 2015 05:17 PM
Fedupdave42169
Oct 23, 2015 09:58 AM
Evil_Capri
Sep 25, 2015 12:56 PM
Steve@CJPP
Sep 24, 2015 06:58 PM
