Dead pedal from CDC now available
Old 10/29/07 | 01:37 PM
  #61
krnpimpsta's Avatar
Originally Posted by jayguy
krnpimpsta,
http://www.autovation.net makes pedals that bolt on. The only problem I've had with them is getting the top two holes drilled on the brake pedal, and there is no real secure way to mount the dead pedal. I've tried using drywall inserts and screwing into them (the screws go thru the carpet and into a foam block), but they're a real B*TCH to line up right.
As you can see in this pic, there are 4 bolts holding the gas pedal on, and three on the brake and clutch pedals.
JayGUY, how slippery are these pedals? How about when wet? (compared to stock)
Thanks.
Old 10/29/07 | 02:01 PM
  #62
Ultimate Pedals's Avatar
We're offering discounted pricing on our pedals sets.
http://forums.bradbarnett.net/showthread.php?t=72950
Basic set starts at $59 for our shiny smooth withour grip inserts finish.
Deluxe set starts at $85 for our shiny smooth withour grip inserts finish.
Our footrest covers the entire area and provides excellent grip wet or dry.
Old 10/30/07 | 06:14 AM
  #63
Boltzman's Avatar
Originally Posted by Ultimate Pedals
We may have an option that would be a close match to the CDC pedal look including a dead pedal.
More to come.
Whats the ETA? Ballpark figure is OK. I've waited this long,so no biggie
Old 10/30/07 | 10:30 AM
  #64
catman's Avatar
+1!!!
Old 10/30/07 | 12:08 PM
  #65
spike's Avatar
Hoping for something like this
I guess I was hoping for something closer to this little pic. A full coverage dead pedal that plays on the 3 rubber strip idea. Is that what UltimatePedals is shooting for? Or will it be more of the rubber circles?
Attached Thumbnails Dead pedal from CDC now available-deadpealmatchforcdc.jpg
Old 10/30/07 | 01:39 PM
  #66
I will post some drawings shortly.
I don't know about you, but I think the gas pedal needs to have more grip strips.
Rob
Old 10/30/07 | 02:22 PM
  #67
How does this look for the footrest?
Old 10/30/07 | 03:32 PM
  #68
spike's Avatar
You've got my attention. Would the rubber strips be a the same thickness as the GT500 pedals? The rendering makes them look a little thin (or they're spaced a little farther apart.. I can't tell). If yes, then I'm sold!
Old 10/30/07 | 03:51 PM
  #69
What thickness are the GT500 rubber strips?
Old 10/30/07 | 03:58 PM
  #70
spike's Avatar
I think the strips on the GT500 pedals have the same thickness & spacing as the strips on the stock pedals if you have access to a stock stang. They're just not as noticable without the aluminum. But I could try to measure when I get home.
Old 10/30/07 | 04:48 PM
  #71
Thanks, we don't have access to stock mustang pedals.
  #72
BlueGT's Avatar
After all this time, the CDC pedals are a disappointment. There's virtually no coverage.
I think spike has the right idea. The new Ultimate Pedals design looks promising. I'll be watching closely.
Old 10/30/07 | 05:34 PM
  #73
mikes rx's Avatar
Originally Posted by metroplex
Bump:
I'm also looking for a dead pedal that mounts securely to the chassis (somehow) and also well-engineered. If I find one, I can finally remove the clear plastic covering off the carpet.
Saleen's dead pedal mounts the same way as what CDC's does.
I would post a pic of my setup, but unfortunately my car is in the shop currently. I would say that maybe Thursday PM I can show it.
...what I have is the CDC pedal set and the Saleen dead pedal bracket and pedal.
IMO, the CDC dead pedal looks like a thin sheet of aluminum with 3 rubber stick-ons, and looks almost out of place compared to the regular pedals.
Old 10/30/07 | 05:39 PM
  #74
AFChief's Avatar
Yuck! I'll be happy with my Autovation DP......
Old 10/30/07 | 06:04 PM
  #75
randy_tho's Avatar
How do the Ultimate dead pedal and Autovation dead pedal mount?
Old 10/30/07 | 07:08 PM
  #76
Our Ultimate Pedals dead pedal mounts with stainless steel self tapping screws directly thru the carpeting into the block that creates the footrest ledge.
Old 10/30/07 | 07:23 PM
  #77
AFChief's Avatar
Autovation was with self tapping screws. I drilled holes and then used silicone glue in the holes and "wet" set the screws. I backed my pedal with a cut piece from a $1.99 rubber mat so there is rubber showing in the holes.
Old 10/30/07 | 08:03 PM
  #78
randy_tho's Avatar
For the autovation, I don't like the idea of drilling holes in the sheet metal.
So there is a block that sets loose under the carpet and the pedal mounts to that. Better than drilling holes in the metal. How stable is it?
Old 10/30/07 | 09:56 PM
  #79
spike's Avatar
UltimatePedals, this should help: strip thickness, separation, and fwiw length of the longest strip.
Old 10/30/07 | 10:44 PM
  #80
n8rfastback's Avatar
the dead pedal is a great idea but i always ride the clutch.... so i wont need one...
althought they do look pretty good, im very tempted
Quick Reply: Dead pedal from CDC now available
