Best method of attaching billet
Old Apr 27, 2008 | 12:21 PM
Mackitraz's Avatar
I have several pieces of billet-y goodness that I want to attach, like an Action Artistry trim ring for the door mirrors and a couple of other things. However I have a problem, the double sided tape I've received with the parts is around a 1/16th of an inch thick, so if you mount the parts with it, it sits up a little, and doesn't fit right.
How do you guys attach stuff to your cars? I've never used 3M double-sided, but I wonder if it's much thinner. I also thought about glue, but I might want to take the stuff off eventually if I get tired of the look.
Thanks for any advice.
Old May 1, 2008 | 03:54 PM
Boltzman's Avatar
Silicone adhesive
Old May 1, 2008 | 06:12 PM
Mackitraz's Avatar
Originally Posted by Boltzman
Silicone adhesive
can you get it off the oem parts later? is there any problem with discoloration to the plastic?
I've used it before, but not on this kind of plastic, so I thought I'd ask. I was thinking a glue would be necessary to get the parts on as snug as possible.
Old May 1, 2008 | 08:13 PM
Boltzman's Avatar
just use fishing line to separate ,then try goo gone or something like that. Try small area first to test for discoloration.
Old May 5, 2008 | 12:29 AM
sound wave's Avatar
i have the action artistry chrome ring for the mirror control. i just used the 3m double sided trim tape. works great. i don't notice any gap... although, i just measured it and it is about 1/16" as well.
Old May 5, 2008 | 12:33 AM
Mackitraz's Avatar
I got Scott Drake door pin surrounds, and it's pretty obvious they don't sit right with just double sided tape. I probably should have pointed that out in the process. On the other hand, I'm not totally sold on the look, so I want to make sure it's removable without damage to the interior plastic.
Old May 5, 2008 | 12:46 AM
sound wave's Avatar
might sound really ghetto, but why don't you just use some elmer's school glue? almost positive that it won't damage your plastic... won't come off unless it gets soaking wet... if it does fall off, which i doubt it will, just glue it back on.
it will hold strong enough, but should release cleanly.
i don't know... just a thought. never tried using that glue for this sort of stuff, but seems like it will work.
Old May 5, 2008 | 12:50 AM
Mackitraz's Avatar
I just got some silicone sealant, going to see how that works. If it doesn't (I can imagine heat being a factor, not sure) then I'll think about it. lol What made you think of elmers?
Old May 5, 2008 | 06:31 AM
Boltzman's Avatar
How about a glue stick
Old May 6, 2008 | 02:49 AM
sound wave's Avatar
idk. hehe. just was trying to think of the mildest glue that came to mind.
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
NC14GT
Sep 10, 2017 04:47 PM
NC14GT
Sep 27, 2015 05:35 PM
NC14GT
2007-2009 Mustang GT/CS
Sep 27, 2015 03:03 PM
