Autometer electric water & oil gauges installed
Old Apr 29, 2005 | 12:23 PM
MTAS's Avatar
Originally posted by O5GT@April 29, 2005, 2:12 PM
why didnt you use a "t" fitting and use your factory guage, and sending unit at the same time?
I thought about that, but since I was familiar with doing it this way (from my other Stang), I felt comfortable enough to just ground the stock gauge and be done with it. No other reason really
Old Apr 29, 2005 | 12:35 PM
FordRacing's Avatar
Dave were you albe to finish off the water temp?
Old Apr 29, 2005 | 03:05 PM
MTAS's Avatar
The correct adapter (metric to 1/8" NPT) will show up on Tuesday. I don't know why Autometer doesn't use the same size sensor for mechanical and electric gauges! I'll probably wait until the weekend to install it, since I'll have to reroute the wire I previously ran, and will end up losing a little coolant when I pop that plug out of there I'll post a pic of where the adapter/sensor goes, maybe even a few pics of what temp our cars are running at when they're fully warmed up. On a related topic, I'm using the Predator to adjust the temp at which the cooling fan kicks on. I'm gonna have the high-speed fan kick on at 185 or 190, and shut off at 180.
So the bottom line is this - if you put in a mechanical water temp gauge, you're going to need Autometer part number 2275. If you put in an electric water temp gauge you'll need Autometer part number 2268.
Old Apr 29, 2005 | 10:14 PM
FordRacing's Avatar
Here is a picture of where it goes.It's not a good picture but you will get the idea.
[attachmentid=19578]
Old Apr 30, 2005 | 04:52 PM
MTAS's Avatar
At least it's easy to get to! On my previous stang, a 96GT, there's no way I could have used that spot for a sensor - impossible to access without dropping the K-member :bang: Looks like you have a kryptonite leak there Gordon Thanks for the pic though
Old May 27, 2006 | 06:34 AM
HiRoller's Avatar
I just bought an A/F ratio gauge and the DPIC from autometer....I bought the E-Pod gauge console that fits right on top of the steering column cover. It replaces the factory cover and looks like the old gauge package from the 65-66 mustang.
Where do you tap into the dimmer circuit????
Old May 27, 2006 | 06:41 AM
HiRoller's Avatar
Almost forgot.....here's a pic
Old May 27, 2006 | 07:15 AM
MTAS's Avatar
Hey Lee - wish I could help, but I didn't tap into the dimmer wire. My gauges are lit all the time. Maybe dustindu4 can chime in here, I think he tapped into the dimmer wire. If not, then I'll talk to mustangshadow today - he'll be at my house in a few hours.
Ecostang
Nov 3, 2022 08:50 PM
Mpaps
Oct 11, 2017 08:06 PM
Jul 8, 2016 08:53 AM
SMOKE46
Sep 6, 2015 09:40 PM
