13/14 computer, harness, gauge cluster and steering wheel conversion
Hello,
I see there is a long thread detailing swapping the 2013 cluster into an 05-07 S197. I have a need to go a step further. I need to convert the majority of the wiring over to 13/14 so that I can run the plug and play motec system. Step 1 is to get it running on a 13/14 computer with working cluster and steering wheel controls. I do not want to swap the interior.
I currently have the following :
2014 Cluster
2014 SteeringWheel
2014 Body harness
2014 Engine harness
2014 Processor
2014 Body Control Module
2014 ABS module ( as well as GT350 R abs module )
2014 Throttle Pedal
Has anyone done similar? Can you think of anything else that I would need? My guess is interfacing to the Heat/AC may be an issue.
Thanks!!!
Mike
2014 Cluster
2014 SteeringWheel
2014 Body harness
2014 Engine harness
2014 Processor
2014 Throttle Pedal
Thanks!!!
Mike
The Analog Admin!
Received 2,992 Likes
These Maybe Helpful!
https://themustangsource.com/forums/...e-info-550475/
Another Conversion Topic!
https://themustangsource.com/forums/...-morph-549411/
Has Wiring Diagrams on One of His Links.
Mgb,
KC
Mgb,
KC
