Will a shorter tire mess with the computer?
I am looking to get the saleen knockoff wheels from mustang tuning, but don't want to use the same size 55 series tire that ford will be using on their 18's. I want to lower the car with the eibach pro kit so that it looks good with a 265 35 18 tire. Will this screw with the computer since it will be shorter height than stock? What about the speedo? Thanks
ps I am sure a tuner(predetor/sct) could adjust for this change but I would rather avoid having to deal with it.
you will be going about 6% slower than your speedo reads, so if you are going 60mph, your speedo will tell you you are going about 65. Plus the wheel well gaps will be HUGE, and you will problably have issues with speed bumps because you are lowering the car a little over 1", plus reducing tire hieght by 2 inches, which means you will lose at lease 2" of ground clearance. Lowering will help the wheel gap from the top of the wheel to the fender, but will make the gaps on either side of the wheel really big.
I found this to be helpful when deciding on wheels.
http://www.1010tires.com/TireSizeCalculato...p?action=submit
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
