valve covers
Old Oct 17, 2006 | 06:40 AM
Lenster's Avatar
valve covers
Hey did anyone pain there valve covers yet? I would like to paint mine Yellow but am not sure how it would hold up. Plus I would not wan to paint the factory ones either. Any ideas?
Old Oct 17, 2006 | 07:12 AM
traffic142's Avatar
I painted mine, infact mustang monthly has an article in how to change out your cam covers (yea old school is Valve cover). I have painted both of my mustangs covers. Just got to disconnect a bunch of wires and such. The gasket is reusable. And if you got basic hand tools (need atleast a universal for your sockets), you can do it. You gotta pull the coil packs (no biggie). Wash it with a degreaser (I used simple green) and used some sand paper to rough up the surface, used engine primer and then painted it. Mask off the areas you don't want painted. It will take you about the same time to prep and paint as it does to remove and install them.
If you want to buy after market powder coat....this is one location
http://www.mossmustang.com/Shop/View...eIndexID=54652
There are others.
if you paint them, You must tape a small cloth over the painted portion to keep it from getting scratched as you install them.
IF you have a 07, for some weird reason Ford put a tab of plastic on the bottom of the battery box protruding toward the engine. it has no function. I used a hacksaw blade to wack it off and it came off easily. You will need to cut it off to get the cover off.
Good luck
Old Oct 17, 2006 | 05:30 PM
GTRacerX's Avatar
Question
There are others.
Good luck
Which Issue of Mustang Monthly? Also how do you get the chrome look?
Are they painted with chrome paint or plated chrome?
Old Oct 17, 2006 | 05:48 PM
jadeuel's Avatar
Painted mine with Base/Clear as is on the exterior of our cars...preceded by an aluminum acid etch primer...They have been painted like this for 4000 miles with no issues what so ever, they still look just as good as when I first reinstalled them...you can also remove the battery box fairly easily and save your self the hacksawing.
Attached Thumbnails valve covers-plenum-cover-002.jpg   valve covers-plenum-cover-001.jpg
Old Oct 17, 2006 | 09:01 PM
Lenster's Avatar
Hey looks awsome.. So you took them off the car? Did you go to ford to get amatch on the paint. And i guess its not heat paint then.. Also not sure If i should buy a new set and then paint them????
Old Oct 18, 2006 | 05:04 AM
jadeuel's Avatar
Removed them from the Car on a Thursday evening, Cleaned masked off the grommets and vents I was not removing. Primed with three coats. Painted Friday Mid Day and clear coated. Reinstalled Saturday morning wrapped in T-shirts. Started the car and let it warm up and then I didn't drive it until Sunday. I went to an auto body paint supplier...PPG Store and had them mix the paint for me...they have all the codes. This is not heat paint and it has been flawless. Even after a long drive you can still touch the valve covers with your bare hand...they are hot yes but not hot like headers. My think was they paint motors to match cars on all the hot rod shows like overhaulin...and some of the paint supply guys told me it should not be any problem provided they are cleaned and primed properly to begin with.
Old Oct 18, 2006 | 06:33 AM
Lenster's Avatar
Sounds great.. Hey are the valve covers aluminum or plastic? Anddo you know how much a set costs from ford??
Old Oct 18, 2006 | 08:21 AM
jadeuel's Avatar
They are not plastic, the V6 Cars have some sort of Composite ones on them the GT covers look and feel like aluminum but may be some other alloy... No idea on new ones except for the Ford Racing ones that go $300-$400 for Silver, Black, Blue, and Chromed.
FYI I was able to re-use Gaskets as they are rubber...and were about new. Also requires 2 small beads of Permatex or the like where the front engine cover meets the head.
Old Oct 18, 2006 | 10:20 AM
First Stang's Avatar
Jadeuel: Did you a spray painter?
Old Oct 18, 2006 | 10:25 AM
jadeuel's Avatar
Spray cans for the Primer, HVLP for the base coats and clear coats.
And a very Cheap one at that...but I am not doing production work so I couldn't justify the price of a high end gun...Cheap import set of guns from auto body paint supply store...Primer Gun/Base Material Gun/Touch up Gun just over $100.00
Old Oct 18, 2006 | 08:02 PM
Boltzman's Avatar
I want to buy chrome ones but have zero time to install..How many hours would it take a qualified mechanic to do this?/Mine charges 70.00 an hour.
Also MTAS (member on this forum) said he had his done a while ago by a guy that would send you painted ones for a low price as long as you sent your old ones to him..anyone doing that anymore?/
Old Oct 18, 2006 | 08:31 PM
pegasusphototx's Avatar
My brother and I changed mine out in about 2.5 hours in my driveway with BSing and such... so I would think a mechanic should be able to do it in 1.5 or so.
-danny
Old Oct 18, 2006 | 08:33 PM
Boltzman's Avatar
-danny
thanks
Old Oct 19, 2006 | 01:11 AM
hireman's Avatar
their magnesium
Old Oct 19, 2006 | 01:25 PM
Lenster's Avatar
Sounds great again.. Yeah I will def try to buy another set to paint then put them on.... Want to keep stock valve covers for resale in the future..
Old Oct 19, 2006 | 02:13 PM
scramblr's Avatar
I had mine done from the same guy as MTAS. Cost us around $120 shipped for powder coated. Would seem to me that after all the parts, paint and time, may be worth just getting a local powder coater to do them for around $100. IMO...
Old Oct 19, 2006 | 05:14 PM
jadeuel's Avatar
Didn't think I could find a match for Legend Lime...So I took the sure bet.
Old Oct 20, 2006 | 10:41 AM
Lenster's Avatar
Wow.. the red looks great .. Do you have hte number or email of the guy who did yours.. Seems that if they are powder coated for 120.00 its worth it. espaecially knowing that someone already used them and liked it..
Old Oct 20, 2006 | 11:10 AM
scramblr's Avatar
He's out of Florida and isn't doing it any more. I'm sure there's a powder coater somewhere around where you live that can hook you up...
Old Oct 20, 2006 | 05:40 PM
SlamMan02's Avatar
scramblr- Can you post more pics? Thanks
