TorchRed05 Has Been Lowered
didn't use the camber plates I still need to take it in for the alignment. I used the Eibach Pro Kit.
Adrenalin - thanks for the instructions they were VERY Useful!!!
I know, I know, I'm working on the stripe issue. don't know if I should repurchase a new set or extend them with spare stripes I have...that would probably look really tacky i'm thinkin.
NOPE...none at all which I'm very surprised. I can do a tight u-turn and no rubbing. Offset is +42mm . Doesnt hit going over bumps, nada. The z9's are SWEET! Good choice.
Didn't you keep the tire diameter the same when you went to the 20's? 255/35/20's? If so, there wouldn't be any chance for tire rub, unless you just lowered it too much.
BTW, the black out panel looks a lot better than I thought it would with the stripes. That has now moved up on my mod list. Any pics of the back end with the sun shining on it so it's not in the shade?
robjh22
9/8/15 12:31 PM
