Tire Question?
Old May 31, 2005 | 05:33 PM
TN615's Avatar
OK.... I have searched but I'm a mathematical idiot…
I just ordered 17x9's for my 05 and I want to go with 285’s on the rear and 255’s on the front.
I want to stay with the 40 sidewall height though…
Is this possible and if so how do I find out what I will need to do to keep the speedo correct?
Thanks for any help!
Old May 31, 2005 | 05:37 PM
celticstanger's Avatar
Try this - http://www.1010tires.com/TireSizeCalculator.asp
I think if you enter invalid combo's, it flags it for you. Also tells you how far off the speedo will be, if I recall correctly.
Old May 31, 2005 | 05:43 PM
TN615's Avatar
I'll try that... Thanks.
Old May 31, 2005 | 05:45 PM
SixtySix's Avatar
You'll want to shoot for an overall diameter that stays the closest to your stock setup to minimize the effect on the speedo, which is roughly 27" (not including any tenths).
TN615's Avatar
Ok.. just tried it I says I should go with a 275 45 17...
It says the 40's could result in brake failure?
Is that right?
Old May 31, 2005 | 05:47 PM
TN615's Avatar
So do you think 25.66 is to small?
Old May 31, 2005 | 05:51 PM
TN615's Avatar
OK... I tried tire rack, and they don't sell a 275/45/17...
Any suggestions?
Old May 31, 2005 | 05:58 PM
Any suggestions?
Tried here - http://www.discounttiredirect.com/direct/home.do ?
Old May 31, 2005 | 06:26 PM
TN615's Avatar
Ya... thanks though... they don't have them either....
I went went with 275/40/17's all around...
Went with the Firestone Wide Oval's.
Old May 31, 2005 | 06:38 PM
SixtySix's Avatar
You'll be fine, I don't know what the brake thing was all about :scratch:
It's what Rikman has on his car:
Clinky Linky
Kestral
Sep 5, 2015 11:50 PM
Sep 2, 2015 07:33 PM
Kestral
Sep 2, 2015 06:52 PM
