those with metal rear window louvers
Old Aug 4, 2007 | 03:16 PM
traffic142's Avatar
Angry those with metal rear window louvers
I bought a set of aluminum louvers for my wifes GTCS. I prepped it as they suggested, let the brackets cure for 24 hours(or adhere), then installed the louvers. After about a week, the bracket came unstuck in the upper left corner. I cleaned it off again, used some more 3m tape, let it cure and went on with the louvers. Now almost a week to the day, it has become unstuck again.
I thought I may have the thumbscrews too tight, not letting it have some slack when it got hot in the sun. Well that did not work either.
Need suggestions from you all on how to fix this,
Thanks in advance
Old Aug 4, 2007 | 03:38 PM
loosen the thumb screws and see how big of a gap is between the louver and the bracket. You louvers may need a little tweeking untill they set close to the brackets
Old Aug 4, 2007 | 05:25 PM
rocket88's Avatar
Did you silicon around the edges of the brackets?
Old Aug 4, 2007 | 07:33 PM
traffic142's Avatar
yes, just as they say do.
Old Aug 4, 2007 | 08:25 PM
dmhines's Avatar
I have the Astro Hammond ALuminum louvers on the back. Before installing them I bent and tweaked them so the laid perfectly flat on the rear glass ... it involved slightly bending them all the way down on both sides to give them a slight curve ... just like the back glass. Now when I fasten them down there is 0 pressure being excerted on the mounting tabs.
Old Aug 5, 2007 | 12:04 AM
gremlin190's Avatar
Blah,don't feel like searching for my old post. Think it was louvers for cheap... Anyway, call Astra, they will send you new brackets that are twice as long. That will do the trick. A bunch of us had the same issue
Old Aug 5, 2007 | 06:39 AM
traffic142's Avatar
do you have the contact number?
Old Aug 5, 2007 | 07:30 AM
http://forums.bradbarnett.net/showth...=louvers+cheap
contact numba is on page 5 I believe
Old Aug 5, 2007 | 09:11 AM
traffic142's Avatar
thanks
I have also emailed the company. My slats are or do not lay flat on the window. That may be it.
Old Aug 9, 2007 | 02:17 PM
traffic142's Avatar
Thanks for all the help on this problem.
Old Nov 2, 2007 | 07:55 AM
gofarlow's Avatar
Raising an old thread. I have the Astro Hammond Aluminum louvers and I am now on my third bracket on the top passenger side. I think mine may need some tweaking since the passenger side it seems to shoot up straight towards that top bracket instead of sitting near the window as it curves towards the roof. When everyone said they tweaked the louvers did they bend them to curve vertically or horizontally and how did you do it without breaking them.
Thanks,
Gary
Old Nov 2, 2007 | 03:17 PM
gremlin190's Avatar
I had the same problem, I didn't doi any tweaking though. I called Astra nad they sent me a bracket approx. twice the size. Almost a year now with no problems.
Old Nov 2, 2007 | 04:32 PM
dmhines's Avatar
I put a bend in them vertically. When done they should lay flat on the brackets without any force. The object is try to get a smooth arch in them from top to bottom. Bend a little then install ... see how it fits ... remove ... bend a little then install ... see how it fits ... etc ...
Old Nov 3, 2007 | 06:49 AM
302svt's Avatar
Subscribing.
Old Nov 3, 2007 | 10:12 AM
gofarlow's Avatar
Thanks for the information. I will remeber to take my time when bending them.
Old Nov 4, 2007 | 08:52 PM
Mach's Avatar
Good info since my louvers will be delivered tomorrow!
Old Nov 8, 2007 | 04:58 PM
mustangshadow's Avatar
I had an issue with my MRT louvers and I just went to the auto store and bought some epoxy to fix the problem. Where the bracket attached to the window it would keep popping up.
Once I put the epoxy on I havent had an issue since.
Old Nov 8, 2007 | 05:48 PM
aircare84's Avatar
I've got the MRT/Visus louvers on mine as well. Installed this Feb. & have not had any issue with the mounting pads as of yet. DD, has seen rain,wind,snow,etc.
MRT also does not have you silicone the edges of the pads. I did let my mount pads set for a day before I hung on the louvers.
Old Nov 8, 2007 | 06:00 PM
Blullitt05's Avatar
It's a sign from Jesus telling everybody they shouldn't have them.
Old Nov 9, 2007 | 03:12 PM
Mach's Avatar
Yup...prolly right...
The Devil made me do it!
Uofmrampage
Aug 2, 2022 02:55 PM
Fords4Ever
Oct 30, 2015 09:07 PM
1001yos
Sep 8, 2015 10:05 PM
robjh22
Sep 8, 2015 12:31 PM
Sep 8, 2015 10:45 AM
