Taillight ?
Old Mar 13, 2005 | 07:25 AM
05WindveilGT's Avatar
Unhappy
How did some of you guys place the inserts in and around the taillight "seperators". I know it can be done with thicker pinstripes that you buy at an Autozone, but I tried it and around the curves is what is giving me the problems. I know the basic concepts of how to apply, but it keeps bundling together (only around the curves). I was applying chrome (to go retro like the old school stangs) around the inlays between the taillights and around the outer edges (which is giving me the problems ). Thanks for any help!!
Matt
P.S. - which products did you guys use?
Old Mar 13, 2005 | 09:14 AM
rap1977's Avatar
I was going to do the same thing when the weather warms up but if it is that difficult around the curve's, maybe I won't even try it. I know someone on here tried it with crome and had difficulty but had no problem with silver metalic. The guy had experience pin striping too.
Old Mar 13, 2005 | 01:16 PM
S197 GT's Avatar
3rd Times A Charm
I had the same problem Matt. I think I'll just grit my teeth and paint them.
Old Mar 13, 2005 | 01:37 PM
Bhead32's Avatar
SOMEONE HAS TO SELL THESE VINYL INSERTS!!!
Old Mar 13, 2005 | 03:10 PM
MilStang's Avatar
I think we have a few people on the site that are good with vinyl. Maybe if we get a pattern made we can have them in black, silver, pink, etc. ..ok, maybe not pink.
Just a thought. If not I will see if I can get someone good with vinyl to make me some and try it out. Or I may just do the painted on version.
Old Mar 13, 2005 | 04:01 PM
rap1977's Avatar
That would be great if someone could make 'em in chrome vinyl. I bet a lot of people would want them.
Old Mar 14, 2005 | 11:09 PM
Bhead32's Avatar
NINO are you listening???
Old Mar 15, 2005 | 01:36 PM
I agree, it goes back to the classic Mustangs with the chrome template around the taillights. I heard someone say that silver metallic picstripe wouldn't bubble up as bad around the curves.
Matt
Old Mar 16, 2005 | 09:13 PM
HOTLAP's Avatar
Have you tried heating up the tape/surface with a heat gun? That may make the tape flexible enough to work?
Old Mar 18, 2005 | 09:00 AM
adrenalin's Avatar
Correct me if I am wrong but I believe it was not chrome that was used. It was bright metallic silver. Chrome is not meant to do curves like that. If you heat it up enough with a heat gun it will become pretty pliable, but after a few weeks it will either peel off because it is trying to go back to its original shape or crack.
Edit: The only way chrome vinyl will work properly is if a template is cut out of a solid piece of vinyl and then applied to the car.
Old Mar 18, 2005 | 09:05 AM
adrenalin's Avatar
If I still had my equipment I would be glad to do this, but unfortunately I don't. If you have the time and experience with Corel Draw, do this.
Take a digital photo of the tail light lens (just one side). Import it into Corel Draw. Create your own template with the line tool. Just use the hairline thickness. Once you have your template done, print out a section on a piece of paper and cut it out. See if it lines up on the car. Just remember when designing it you need to have the proper measurements. Once it looks good duplicate your pattern and mirror one of them. You now have the drivers side and passenger side done. Save it to a cd and bring it to a sign shop so they can cut it out on vinyl for you.
Old Mar 18, 2005 | 09:10 AM
PonyGirl's Avatar
I have a friend who does vinyl decals for 18 wheeler companies, and I will see if she can use my car to measure, and then make these. I know she will, but I have to know people will buy them.
Chrome? ( shiney silver)...
I will check into it this weekend
Old Mar 26, 2005 | 12:02 AM
INTRUDER's Avatar
count me in.. I'll by a set or two.
Old Mar 26, 2005 | 09:01 AM
Mustang Ricky's Avatar
I'm in for a set - assuming that quality and price are appropriate.
..I'm still not sure though about silver, but black works well.
Old Mar 30, 2005 | 11:03 PM
Did you find anything out pnygrl?? I want a chrome bezel?? PLEASE .. hehe
Matt
Fedupdave42169
Sep 30, 2015 08:45 PM
unnoticedtrails
Aug 4, 2015 07:05 PM
SilverHorse-----Racing
05-09 Exterior Modifications
287
Dec 21, 2006 01:45 PM
Stang281
Mar 20, 2005 08:10 PM
HTRDCowboy
Mar 5, 2005 03:43 PM
