Stock 18" Offset & bolt pat?
Old Nov 14, 2006 | 03:19 PM
norcalmustang's Avatar
Whats the offset and bolt pat for the stock 18" rims? Thanks so much. Kevin
Old Nov 14, 2006 | 03:52 PM
cobra1993ky's Avatar
Please add to that the stock 18" wheel width also please, dan
Old Nov 14, 2006 | 04:45 PM
jadeuel's Avatar
As copied from Ford Racing Performance Parts Website....
Old Nov 14, 2006 | 04:53 PM
FLAstangx3's Avatar
Just a note here. When I had my 05 V-6, when I changed out the stock 16" wheels, I had to also add a steering stop. Believe the same would hold true if your going from 17 to 18 also. My 07 came with the 18" Fan Blades, so I'm going thru that again. (Just check it out first before you upsize)
Old Nov 14, 2006 | 05:26 PM
Is the backspacing really important? or does it have to be right on?
  • M-1007-U1885P*
  • Optional wheel on 2006 Mustang GT
  • Fits all 2005-07 Mustangs
  • Polished aluminum finish
  • 5-lug 4.5" bolt circle
  • 6.295" backspacing
  • 18" x 8.5" wide
Old Nov 14, 2006 | 05:31 PM
oh one more thing.. whats the offset in mm?
Old Nov 14, 2006 | 06:03 PM
FLAstangx3's Avatar
+-Bump steer in the front
Old Nov 14, 2006 | 06:09 PM
jadeuel's Avatar
The Back Spacing goes hand in hand with the Offset.
Offset in MM = Backspacing Minus wheel Centerline x 25.4 (to convert to MM)
6.295 - 4.25 x 25.4 = 51.9 mm according to my calculations.
Also see this web site for more info...http://www.rsracing.com/tech-wheel.html#backspace
Old Nov 14, 2006 | 06:44 PM
The rims I want to buy the offset are 25mm, is that the same as the stock 18"s?
Old Nov 14, 2006 | 07:06 PM
jadeuel's Avatar
According to the Calculations the stock 18s are 2.045" offset, so with a 1" offset you would theoretically have to decrease your backspacing in turn by 1" to 5.295" which if you are staying with 8.5" wheels would give you a deeper front lip. Just the best I can figure from the numbers provided by FRPP and the linked wheel info page I found.
Old Nov 14, 2006 | 08:03 PM
So compared to the stock 18" rims, the aftermarket 18X9 25mm rims I want to buy are they going to look funny because of the offset difference???? I really don't want the rims sticking way out or do I want them tucked in
DarrenGT
Apr 2, 2020 11:52 AM
Raynier Leonardo
'10-14 Exterior Modifications
27
Mar 2, 2017 12:08 AM
samjluck
Sep 17, 2015 10:24 PM
jim010
Sep 14, 2015 10:15 PM
M3hunter
Sep 10, 2015 09:26 AM
