Side mirror removal
Old Nov 3, 2006 | 12:17 PM
2006stang's Avatar
Side mirror removal
How hard is it to remove the side mirrors? Anyone have a step-by-step procedure? I will have my car stored in the garage 99% of the time this winter and I was thinking about dropping off my mirrors at a friends bodyshop and have him to paint them torch red when he has some free time this winter. Any special tools needed? Thanks
Old Nov 3, 2006 | 03:20 PM
70MACH1OWNER's Avatar
Here are some instructions to do Muth signal mirrors. Just use the part of the instructions to remove the mirrors. http://www.muthco.com/techsupport/pdfs/21001140.pdf
Scott
Old Nov 3, 2006 | 03:27 PM
G.T's Avatar
G.T
Here's everything related to the removal and installation of the exterior rear view mirror from the 2007 workshop manual
File Type: pdf
File Type: pdf
File Type: pdf
Old Nov 10, 2006 | 07:08 PM
WindveilBlue's Avatar
You can definitely paint them. I've seen them but to be honest, I think Midwest Mirror Inserts give a better look. Matter of taste. Good luck.
Old Nov 10, 2006 | 08:21 PM
redbullet's Avatar
Follow the directions above and before you start sanding, remove the glass from the assembly. Also sand the mirrors smooth for a shiny finish. Otherwise the texture will dull the appearance.
Old Nov 11, 2006 | 12:26 PM
Kenichi Mifune's Avatar
The Sail Panel and Switch removal is unclear.
Do they just pull/pry off?
Old Nov 11, 2006 | 06:47 PM
redbullet's Avatar
Yes, and the harness unplugs
Fedupdave42169
Oct 23, 2015 09:58 AM
MRGTX
Sep 16, 2015 08:08 AM
jim010
Sep 14, 2015 10:15 PM
Earlsays
Sep 12, 2015 06:29 PM
Sep 10, 2015 12:44 PM
