searched: Roush fog light wiring
I am getting the roush front bumper kit for my car. I have searched all over and can't find what I am looking for. I want to wire my new fogs into my light system so they all come on at the same time. Does anyone know an easy way to do this? I have seen someone on here saying they have done it but I can't seem to find that thread. Thanks for any help you guys can give.
Kyle
Kyle
That is what I'd do also if the wattage of the bulbs was low.
I guess the other option is to wire relays into the fog light switch and run new wiring all the way down to the new lights. That would prevent you from overloading the fog light switch with highpower bulbs..
Rather than running the relays back to the fog light switch I'd think you could just tap into the hot lead for the stock fogs to use as a trigger to a relay. Run a hot lead from the engine compartment fuse box and you're set. When the stock fogs come on it triggers the relay and the new fogs come on.
That would work too!
