Safely removing the GT emblems?
Old Dec 12, 2005 | 11:01 AM
hpaddict's Avatar
Is there a safe way to remove the GT emblems on the fenders? The thing is I need to put them back on as well. Stupid body shop scuffed up the paint around the emblems while they were repainting the car. The only way I can buff out all the scratches is by removing the GT emblems. Any safe way to do this? I need to put them back on as well...
Old Dec 12, 2005 | 12:18 PM
creggleton's Avatar
I used about four long strands of unwaxed dental floss to cut the tape behind the emblem. It takes quite a bit of pressure but works pretty well. Don't forget that there are two pins that you will run into and have to work around. Good luck!
Old Dec 12, 2005 | 12:21 PM
PIKE2244's Avatar
You can also use a hair dryer to loosen the tape.
Old Dec 12, 2005 | 01:15 PM
Shea's Avatar
Go to my cardomain site, page 2.
Old Dec 12, 2005 | 03:18 PM
red454's Avatar
More GT emblem info -
http://forums.bradbarnett.net/index.php?sh...89&hl=gt+emblem
Old Dec 13, 2005 | 07:19 AM
StangNut's Avatar
Using some type of "string" will leave a lot of the tape on the car.
You're better off heating it and pulling it off.
Old Dec 13, 2005 | 08:38 AM
Ascout's Avatar
Like StangNut said....heat and gentle lifting pressure working from one side across did it for me....didn't leave a mark on the paint or any adhesive left behind.
Old Dec 13, 2005 | 10:09 AM
RRRoamer's Avatar
And the emblems are pretty cheap too. If you mess up the adhesive, buy new ones. It's not worth having the emblem sitting there not properly secured.
When they replaced my drivers side door, they had to repaint about halfway down the front and rear fenders, so the GT emblem had to come off. The new one was only billed at $18 if my memory is correct. I kept the old one of course!
09-gt/cs
Oct 15, 2015 10:03 AM
seaclam
Sep 25, 2015 01:29 PM
TMDM
Sep 24, 2015 07:00 PM
jim010
Sep 14, 2015 10:15 PM
