Roush Scoop Drill Bit Size
Old Aug 12, 2007 | 03:42 PM
Alloy 07 RN's Avatar
I am planning on installing a Roush hood scoop. The instructions say use a 5mm drill bit. I went to Sears & Home Depot and didn't see any 5mm drill bit. What is the conversion between metric system and the american system?
I could only find drill bit sizes written as..... 1,95 (huh). HELP!
Old Aug 12, 2007 | 06:43 PM
RedDragon777's Avatar
i know how you feel man, the stock hood scoop calls for a 12mm and 9mm drill bit and i still can not find them so i am just going to let Ford do it when they repaint my hood under warrenty
Old Aug 12, 2007 | 07:16 PM
SoFlaBoss's Avatar
I installed a GTAP scoop on my 05 GT several months ago. I remember checking both Lowes' and Home Depot's drill bit stock and couldn't find exact equivalent to metric sizes, so in some cases I went just under the equivalent. With some people reporting GTAP scoops not fitting flush, I figured going slightly undersize woul result in a tighter install. The install went very smooth and fitment was perfect!
Old Aug 12, 2007 | 07:28 PM
13 MIKE's Avatar
To convert metric to english times it by .03937
example...........
5mm x .03937 = .19685 A little bigger than 3/16(.1875)
Class dismissed.
Old Aug 12, 2007 | 07:32 PM
ARBO's Avatar
I'm waiting for my 9mm & 12mm drill bits to come in from a specialty fastner shop. I love all the metic tools we need for out American cars. I'll bet they're cheap too!
Old Aug 12, 2007 | 07:42 PM
13 MIKE's Avatar
As for the number drills, 1-95, An industrial drill bit set consists of your basic fractional drills, plus a set that is sized by letters, and the tiny ones use numbers.
Here is a link for drill sizes and their decimal equivalent.
http://www.thedirtforum.com/conversions.htm
A chart to hang on the wall should be readily available at that fastener store, or a place that sells industrial tools.
Old Aug 12, 2007 | 08:33 PM
example...........
Class dismissed.
I actually purchased a 3/16 drill bit but the diameter of the bit seems too large for the screws supplied with the roush hood scoop.
Old Aug 12, 2007 | 08:34 PM
Thanks to all that replied!
Old Apr 20, 2008 | 09:53 AM
Forgot to post an updated pic with the roush hood scoop.
EaterofWorlds
Nov 23, 2015 08:51 PM
GLOCKer
Aug 13, 2015 09:55 AM
Detroit Steel
'10-14 Roush Mustangs
Jul 13, 2015 01:04 PM
