Problem with HIDs, delay in fire-up, R side only.
05 GT, vvme 5k kit purchased/installed 01/2008, no issues until recently.
So I turn on my headlights and the Drivers turns on no prob, but the Pass. doesn't (90% of the time.). Sometimes it takes 5sec - 3min. Same goes for the foglights. Driv. on, Pass. lags...sometimes (only 5% of the time, if that) I thought it was a ballast, but it doesnt stay off, and the high/low still work.
I've disconnected everything, and reconnected it, checked all wired, and bulbs, switched bulbs R->L, switched ballasts R->L, no matter what I do, it's the right side... WTF?! I emailed the manufacturer, but they sent me an email in Chinese.
I had a less extreme problem like that when I first installed my vvme kit. There was a few times that I would realize driving down the road that my left headlight wasn't on, but I just flipped my lights off then back on and that solved the problem. It hasn't happened for a few months so I guess the ballast/bulb/relay had to just get broken in, I guess.
But that's the only problem buying from vvme, they're customer service is lacking because of the language barrier. Don't get me wrong, they're nice and reply in a timely fashion, but it just doesn't work too well.
But it sounds to me like you did pretty much everything you could do to figure out what's going on. Maybe it's the relay that's malfunctioning?? The good thing is that the vvme kits are cheap$$$ so if you did absolutely have to buy another kit it wouldn't put a huge dent in your pocket. You can buy two or three vvme kits compared to one kit from some of these other HID sellers. But mine have worked just fine so far, so I'm happy with them.
Good luck
Good luck
you probably need to get a relay kit. you can get them off ebay for like $10. it connects the headlights to the battery directly so they will always have the highest amount of power to run them.
I dont understand... they draw less power than the stockers, soooo shouldn't the stock wiring be more than enough?
yes, once they start up. the ignition process is what requires alot of power. and it needs a constant 12v source to power them or you will have flickering, etc. when i had my ac on and stopped at a red light or something the foglights would flicker and go off or something like that. just get once of these for your bulb type - http://cgi.ebay.com/ebaymotors/H4-HI...Q5fAccessories
http://www.vvme.com/hid-relay-harnes...iqsse6gjuepdh2
specifically you should need
http://www.vvme.com/relay-harness-fo....html?cPath=20
but i dont know your set up...you should be using the bi-xenon kit, so you should need the bi xenon harness. also if you check ebay you can probably find one locally...its all the same as far as i can see, but if im wrong, someone oughta chime in and correct me
i had nothing but issues with my vvme kit.
i bought a kit from ddm tuning and it was worked quite well and is alot cheaper.
http://www.ddmtuning.com
plus their customer service is local.
I got mine from Retro-Solutions for both headlights and foglights. Had it since the beginning of the year and still no problems. It may be a little pricier but hey, you can't go wrong with lifetime warranty. When I was installing my kits, I had one ballast that was defective and sent an email to Retro-Solutions to solve this problem. I sent the ballast back and they said they could not locate the problem - therefore they sent me a new one right away! Their customer service are great and they stand behind their lifetime warranty.
Just another option if you can't fix your problem.
I'm running Retro-Solutions headlights and fogs also. Only problem I've had is the need for the relay harness because the passenger side intermittently shuts off. But this is I'm sure due to the fact that I have so many electrical gadgets running in my car and the nightmare UDPs I'm dealing with now.
