NEW PRODUCT: No Drill front plate brackets
Old Jan 28, 2011 | 07:30 AM
Tucker's Avatar
Craig's Custom Mustang Brackets
When I see a good product I get it for my car. If I'm going to put it on my car, I'll put in on my web site. This is a great idea and we stocked up with most every kit available
30 of the 50 U.S. States require a front license plate to be displayed. Ford has designed the stock Mustang front fascia's with pre-molded dimples (in most cases) which provide a means/location to attach the license plate using boring type screws. Not only does this ruin your front fascia, it can reasonably reduce the possibility of resale of the car to potential customers in on of the other 20 states and what if you relocate to one of these other 20 states. Now you’re left with two ugly holes in the front of your car.
So if you've "Been tempting fate without a front plate", the small amount you pay now will be much less painful than the $75-$150 you will pay later in traffic citation fees and court costs. And it looks good also! This bracket is hand crafted out of quality aluminum and comes with all stainless steel hardware. What does that mean? "No rust, no corrosion and show quality!"
•Satin powder coated surface
•Requires no maintenance
•Aluminum Construction
•Stainless Steel Hardware
•Easy to install
•100% Satisfaction Guarantee
No Drilling.
Eliminates the concern for drilling directly into the bumper, causing permanent holes.
Easy to Install.
Installation takes only a few easy steps and can be in place in less than 10 minutes.
No rust, no corrosion and show quality.
Hand crafted out of quality aluminum and comes with all stainless steel hardware.
No scratches or annoying vibrating sounds.
Rubber bumper protection in place, so no metal parts of the bracket ever touch the painted portion of the car.
Just $44.95 - $47.95
These are not a 1 size fits all. CCMustang Brackets took the time to measure GT's, V6's, GT500's Roush's, Saleens and so on and made kits specific to each model for a perfect fit!
DRILL FRONT PLATE BRACKET
Here's a quick video we did when we installed it on our 2011 GT: http://www.youtube.com/watch?v=El9lo...&feature=feedu
Old Jan 28, 2011 | 07:50 AM
SoFlo Mustang's Avatar
Fantastic idea. Gotta love Fl tho (no front plates required)
Old Jan 28, 2011 | 08:21 AM
n4agoodtyme's Avatar
I have had this item for the past couple of years. It has worked FLAWLESSLY on my 08 GT/CS. Off for shows, on for street.
Old Jan 28, 2011 | 11:10 AM
watchdevil's Avatar
It's a shame the factory does not address this issue. The front of our Fusion is ruined with a bracket installed by the dealer. This could all simply be avoided by engineering being thoughtful enough to place the mounting points inside the lower grille where they would be hidden.
Old Jan 28, 2011 | 11:48 AM
TheRealOne's Avatar
Does this fit if you have the SHR lower grill inserts? Has anyone tried it?
Old Feb 2, 2011 | 06:32 PM
impetus maximus's Avatar
how fast can you drive with these?
when i picked up my new mustang, they handed me the keys, inspection sticker/plates.
they said the mechanic out back will put them on for me. i said thank you and drove home
my state requires front plates. i still don't have one
Old Feb 2, 2011 | 07:48 PM
HPwhitevert's Avatar
i think the drilled front bumper for a plate bracket is a legal thing that scares the dealerships in big cities as I have seen V6 Mustangs through GT-500's hacked for front plates. I specified to my dealer " no front bracket" LOL, the dumb asses removed the bracket and delivered my car with rough drilled holes in the front bumper.
This is a great idea if you can get to the dealer before the prep guys do their thing...
Old Feb 2, 2011 | 09:20 PM
825LTRGT's Avatar
I have the SHR insert in my CS. The insert needs to be notched to fit 100%. It can be used without notching but there is a gap between the insert and the facsia.
It has not moved in over a year in all weahter conditions including below 0.
Old Feb 3, 2011 | 06:10 AM
Tucker's Avatar
All normal speeds are fine, although it says on the box that it has not been tested at "excessive" speed.
If you were going to the road course, drag strip or auto cross I'd remove it anyway.
I keep mine in the trunk. it's so easy to install that if I get pulled over I will claim I forgot to put it back on after washing the car and put it on right then and there.
I bet 99% of the officers will be fine with that.
Jay
Old Feb 4, 2011 | 12:54 AM
bob's Avatar
bob
Same here, been almost 2 years
Old Feb 4, 2011 | 08:03 AM
Bennyandthejets's Avatar
I remember physically taking the plate out of the drillers hands right before he drilled. I had told them not too but since when do they listen. It was a close one. Then of course a freeway tire carcass hit my bumper so I've got a big hole in it anyway.
RoushRS3
Sep 29, 2015 08:03 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
Airborne42
Sep 25, 2015 05:14 PM
Evil_Capri
Sep 25, 2015 12:56 PM
Sep 16, 2015 06:44 PM
