Need Tips on Removing Trunk Emblem
Old Feb 15, 2007 | 05:11 PM
Northwest GT's Avatar
If I had a straight shot at the edge, I'd be OK. But, I have a Silverhorse Racing trunk cover so the trunk emblem is set down in a recess. I don't want to remove the whole cover.
Any of you guys who have removed that emblem, will the standard trick of heating it up with a hair dryer and then prying at the edges still work?
Old Feb 15, 2007 | 06:19 PM
Got Oatz's Avatar
Heat it up with a hair dryer, then use some type of tool whereby you can grab at the edge around the keyhole. I forget what the tool is actually called, but it has a 90 degree bend, then kinda bends up...it is actually used for removing cotter pins....
That's what I used, and it popped right off......
Mike
Old Feb 15, 2007 | 06:46 PM
Legacy Tms Member
Cotter Key puller.
There's a picture of it in our directions - you can go over to our "How to" section of our website and download it in PDF format.
HTH.
Old Feb 15, 2007 | 08:18 PM
Sounds good. I'll look for the tool tomorrow. By the way, I still think the trunk cover looks great with my latest modifications.
Old Feb 17, 2007 | 04:44 AM
nole_trainer's Avatar
Using the above method, my came right off. Even could have re-used the original but decide to use new one made by Marcello
Old Feb 17, 2007 | 07:18 AM
BADGT350's Avatar
Use the hair dryer and if you can get some dental floss started at the corner you can lift it off.
Old Feb 17, 2007 | 09:07 PM
Well, I got it off. But, it was a struggle. Maybe I didn't give it enough heat. It was still stuck on there pretty good. And, there's not a whole lot of clearance to get the cotter pin puller and then a flat blade screwdriver in there. Having the trunk cover on made it difficult. I don't think I could have gotten dental floss or fish line in there. I think if I was just prying it off without the cover it would have been a lot easier because I would have had a straight shot at all the edges of the emblem.
Anyway, it did come off.
seaclam
Sep 25, 2015 01:29 PM
TMDM
Sep 24, 2015 07:00 PM
jim010
Sep 14, 2015 10:15 PM
Sep 10, 2015 12:44 PM
