Which Lug Nuts on Razors
Thanks guys for the inputs, unfortunately my wheels came with no centering rings, so I went and bought 4 from the local speedshop. The only difference from the one I saw on Glenn's page is that mine are tapered at one end.
So I don't know if they will fit ?
The picture is blurry but you can see the tappered lip near my fingers
I think you'll be fine. Mine are plastic but I don't know why yours wouldn't work.
Thank you guys,
I did install them and they fitted fine in the wheel as the wheel is tappered at the end.
On the hub itself it was thight, I had installed it on the wheel first but it was very hard to get the wheel in place, I put it the best I could and then srewed the lugs slowly by alternating until it got falt against the brake disk. It was long but I think it was the safest way.
No vibration and everything is fine.
