Which Lug Nuts on Razors
Old Apr 27, 2008 | 07:21 AM
Dineau's Avatar
I'm about to install my Shelby Razors and was wondering if I can use the original Lug Nuts ?
Will the socket of the wrench fit ?
Old Apr 27, 2008 | 12:33 PM
Deric's Avatar
Mine came with lugnuts but I don't know if they are the same at the factory ones. I can check tomorrow if you like. I'm at work really late tonight.
Old Apr 27, 2008 | 03:45 PM
Dineau's Avatar
Also did you guys had to use centering rings ?
Old Apr 27, 2008 | 05:05 PM
click on my sig ..... I don't think the stock lug nuts will fit into the holes in the razors ...
Old Apr 27, 2008 | 05:15 PM
ramairgt1's Avatar
The stock lug nuts do not fit the razors, your wheels should have come with new lug nuts.
You also do not need centering rings
Old Apr 27, 2008 | 06:47 PM
nm3's Avatar
nm3
I bought the Gorilla lug nuts and American Racing hub centric rings.
Old Apr 28, 2008 | 02:32 AM
Deric's Avatar
My wheels came with centering rings as well.
Old Apr 28, 2008 | 06:56 PM
Dineau's Avatar
Thanks guys for the inputs, unfortunately my wheels came with no centering rings, so I went and bought 4 from the local speedshop. The only difference from the one I saw on Glenn's page is that mine are tapered at one end.
So I don't know if they will fit ?
The picture is blurry but you can see the tappered lip near my fingers
Old Apr 28, 2008 | 09:20 PM
Deric's Avatar
I think you'll be fine. Mine are plastic but I don't know why yours wouldn't work.
Old Apr 29, 2008 | 05:52 AM
mine are tapered also just doesn't seem top be as much taper as the ones above
Old May 2, 2008 | 03:54 PM
Dineau's Avatar
Thank you guys,
I did install them and they fitted fine in the wheel as the wheel is tappered at the end.
On the hub itself it was thight, I had installed it on the wheel first but it was very hard to get the wheel in place, I put it the best I could and then srewed the lugs slowly by alternating until it got falt against the brake disk. It was long but I think it was the safest way.
No vibration and everything is fine.
Jim74656
May 1, 2023 02:15 AM
Linkspure
Sep 12, 2015 06:33 PM
oldnjguy
Sep 10, 2015 02:39 PM
