just put rims/tires on but have a problem
Old Feb 24, 2006 | 09:47 AM
94tbird's Avatar
I jsut put my rims/tires on, Konig Beyond 18x9.5 275/40/18 all around. I was assured by the place i ordered from that they would fit with no issue. They came mounted on the rims and apparently balanced as well. i see the weights glued on in the rear of the rim. here are my 2 issues
1. The steering wheel is shaking a lot between 40 and 65mph. quite noticable and sometimes borderline violently. What could cause this and how can i remedy this?
2. Wheneve i make an extreme right or left hand turn, ie the steering wheel is turned all the way to either side till it cant be turned anymore, i am getting the wheel rubbing in the wheel well. Is there anything i can do about this?
Thanks for the help
Old Feb 24, 2006 | 10:17 AM
f1-cobra's Avatar
Ron,
Check out this thread, http://forums.bradbarnett.net/index....opic=37789&hl=, for the shaking problem. It could simply be that the factory clips are still on the rotors. Not sure about the second problem, though.
Old Feb 24, 2006 | 10:26 AM
adrenalin's Avatar
I agree with the rotor clips. Remove the rims and take a look. If the clips are there, toss them.
As for the rubbing...have you lowered the car at all? If not, they should fit but that depends on the offset of the rims. If the car is lowered that changes everything. When you turn the wheel, exactly where are they rubbing (ie: hitting the fender, the fender skirt, suspension components, etc...)
Old Feb 24, 2006 | 10:29 AM
blackhat's Avatar
Ron, sorry to hear about the problems your having with the wheels. I hope f1-cobra's suggestion about removing the clips on the front wheels helps and it solves the problem.
Also not sure about the fenderwell rubbing.
Old Feb 24, 2006 | 10:39 AM
94tbird's Avatar
ok so the retaining clips solved the vibration with no issue. now on to the rubbing. the car is not lowered and has all stock suspension. it seems to be rubbing on the inside of the wheel well towards the engine compartment. only when the wheel is turned all the way to its extreme. i can see where it is rubbing inside the wheel well. anyone have any ideas?
Old Feb 24, 2006 | 10:50 AM
adrenalin's Avatar
That sounds like a backspacing issue with the rims. What offset did you end up getting?
Old Feb 24, 2006 | 11:24 AM
94tbird's Avatar
Old Feb 24, 2006 | 11:29 AM
Torrence's Avatar
Take it to an aftermarket rim dealer and have them take a look.
Old Feb 24, 2006 | 11:36 AM
adrenalin's Avatar
Here is a comparison between the stock size and the ones you put on. Basically the backspacing is .8 inches more towards the inside of the wheelwell which most likely explains why you have the rubbing. 7" backspacing versus the stock 6.2". I guess a way of looking at it is now when you crank your wheels all the way, the inner most part of the tire is now .8" further than before.
I do know that other people have managed to put 18x10's on the front with a 7.25" backspacing. How theirs don't rub is beyond me cause when I tried that mine rubbed bigtime.
Old Feb 24, 2006 | 11:47 AM
94tbird's Avatar
is there any way to modify the wheel well at all?
Old Feb 24, 2006 | 11:50 AM
Torrence's Avatar
Ron, I have the number to this great rim place in south jersey that I went to, when I was having problems with my rims. Do you want it? You should probably check them out tomorrow since you will be in Jersey.
Old Feb 24, 2006 | 11:52 AM
94tbird's Avatar
sure. gimme tommorow tho when we meet up. maybe we can stop by there if its on the way
Old Feb 24, 2006 | 11:57 AM
adrenalin's Avatar
you could always but a 1/4" or 1/2" spacer in there but as Torrence said, I'd take it to a tire place and have them take a look.
Get someone to help you. Turn the wheel while somone is looking to see when it hits. As soon as it touches figure out how much more you can actually turn the wheel. If it is just slightly rubbing a 1/4" spacer might be all you need.
I still find this odd that it is rubbing since others have installed the same rims on their cars, however, not sure if they are running 275's either.
Old Feb 24, 2006 | 12:04 PM
94tbird's Avatar
i think ill try the spacers. if thisdoesnt work it might come to a hammer and the wheel well haha
Old Feb 24, 2006 | 12:06 PM
adrenalin's Avatar
Just make sure that if you are using spacers that you put some locktite (not the permanent stuff) on the threads to prevent the lug nuts from coming loose.
Old Jun 5, 2006 | 01:26 PM
2005 Mustang V6's Avatar
I hate to bring up an old topic b ut i just wanted to see if you ever got your rubbing problem worked out? and if so what was wrong with the wheels because i really want to order these rims but i dont wanna have all the problems. Thanks!
Old Jun 5, 2006 | 08:32 PM
STANG_IT's Avatar
Try installing hub rings. I had the same problem and these fixed it. Good luck.
Old Jun 5, 2006 | 10:35 PM
StangNut's Avatar
Since it's already been revived, anyone have a pic or description of the factory clips? I still can't keep my car from pulling left so I thought I'd check for those as a last resort.
Old Jun 6, 2006 | 12:02 AM
official_style's Avatar
i had the vibration problem when i got my rims on, and it was the clips
Mpaps
Oct 11, 2017 08:06 PM
Linkspure
Sep 12, 2015 06:33 PM
Mrmiles1369
Sep 11, 2015 07:23 PM
