Jesse, need your help with my conversion
Jesse,
You told me to ask you questions and here's one
When replacing the foglights from the stock GT to the Shelby fog's, we needed a fog light harness (part 7R328C2981AA) , which I ordered.
However when hooking it up to my stang, the wire for the Airbag doesnt connect to this when removed from the old wire .
How do I go abouts to fix this problem?
Right now the lights and foglights are working, but the airbag light is "on" on the dash...
Any suggestions would be appreciated
Also check my original post about the conversion and tell me what you think about the 2 different wheels?
http://forums.bradbarnett.net/showthread.php?t=53394
The Harness is not a Plug and Play. Most will Simply Cut the Pigtails and Attach to Factory Harness. Oklacop was the one who had his Wired to the Fuseblock for a cleaner Install. DO NOT Attempt to simply plug in. You May cause Damage to car.
kc
kc
kc
kc
Which wheel would YOU go with!?
Originally Posted by 2L8IWON
I haven't hooked up my lights yet, but I plan to do as Kevin said. Simply cut the pig tail off and then hook it to the GT harness.
As far as wheels go I suggest Foose Nitrous
- Jesse
- Jesse
you see i already have to different wheels, and was thinking one of those two,,,lol
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
