How to remove GT fender badges?
Old Apr 25, 2005 | 09:18 AM
ekessler507's Avatar
My wife's vert is being built this week and will be taking the day off work when it arrives to do the mods. Just wanted to know what I was to encounter when I go to remove the GT badges on the fenders. Are they just applied with adhesive foam tape or are there speed nuts on the back that will require me to remove the fender well or something entirely different? :scratch:
Any info will greatly reduce my time and frustration. Thanks! :worship:
EK
Old Apr 25, 2005 | 09:30 AM
PonyGirl's Avatar
Not sure, I think they have prongs on the back, and there are holes drilled in the fenders.
but if you take them off, can I buy one from you? I need just one of them?
Old Apr 25, 2005 | 09:36 AM
OBleedingMe's Avatar
Being that I had to have my GT fender emblems replaced when I had my front fenders repainted due to scratches, I can tell you that there are three holes drilled into the fender for the emblems as well as an adhesive on the back of the emblem. My body shop got them off with no damage to the paint by using pliers wrapped in cloth. Just take it slow and be patient. You don't want the emblem to snap back and whack the paint.
May I ask why you're removing the GT emblems? Just curious.
Old Apr 25, 2005 | 09:39 AM
I am adding the GT300 rocker stripes to my wife's vert and replacing the GT badges with tri-bar pony badges to eliminate the GT duplication on the fender.
EK
Old Apr 25, 2005 | 10:20 AM
black gt 2005's Avatar
Originally posted by ekessler507+April 25, 2005, 9:42 AM--><div class='quotetop'>QUOTE(ekessler507 @ April 25, 2005, 9:42 AM)</div><div class='quotemain'><!--QuoteBegin-OBleedingMe@April 25, 2005, 9:39 AM
EK waste of time. tri-bar will not cover holes, if the stripe is a sticker it peel off after 10 washes. save your money.
[/b][/quote]
Old Apr 25, 2005 | 10:24 AM
rhoover2's Avatar
I have personally done this myself and I used fishing line to cut through the foam adhesive tape. It came off very easy. After cutting through the tape and removing the emblem I used a plastic putty knife to peel off the rest of the tape. There are two mounting holes that are use to align the GT badge and I used the top one to put on the Tri-bar. The other three pins on the Tri-bar I cut off with a dremmel. I bought some 3-M double back tape to mount the Tri-bar. I have pictures of the install if you need them. You can see it here -- http://forums.bradbarnett.net/index.php?showtopic=22216
Old Apr 25, 2005 | 11:56 AM
acadian's Avatar
[/quote]
Please don't post information on which you have no idea what you are talking about. First of all, the tribar pony will cover the stock holes for the GT emblem. I know this because I replaced my GT emblems with tribar ponies, and they did indeed cover the holes. And secondly, if you get a good quality vinyl side stripe (i.e. from graphic express) it will not peel off after 100 washes, much less 10. I have a side stripe from graphic express and have washed my car close to fifty times and it looks as good as it did the day I installed it. The vinyl will last you 3-4 years minimum as long as you be careful to scrub parallel to the edge.
Old Apr 25, 2005 | 01:03 PM
adrenalin's Avatar
Did I hear someone say vinyl is a waste of time
Old Apr 25, 2005 | 06:57 PM
BEACHBOY's Avatar
Hey Eric, check the link below. I changed my GT emblems and the link explains how easy it was and how I did it. Very simple job took less than 20 minutes.
http://forums.bradbarnett.net/index.php?showtopic=19726
Old Apr 25, 2005 | 07:12 PM
Original Sin's Avatar
Yeah, there's only 2 holes. Here's a diagram of where they are (the GT emblems are traced over them so you can see how they're aligned) and what your concept will look like after it's done. And yes, the Tri-Bar will fit over the holes nicely.
Mark.
Old Apr 25, 2005 | 10:28 PM
Vegasjay's Avatar
I used a hair dryer and got them hot, along with using fishing line to cut the foam. Came off great and the emblem's are still mint. There are two hole's like the diagram above and not three. I used some Goo-Gone for the left over addhesieve/foam came right off.
jim010
Sep 14, 2015 10:15 PM
DEPUTY62
Sep 12, 2015 11:12 AM
Sep 10, 2015 12:44 PM
