Headlight/Fog Light Bulbs
Old Sep 3, 2005 | 08:18 AM
Ugabulldog83's Avatar
Post
Folks,
What have you all found to be the best bulbs for the headlights and fog lights to put out the clearest, brightest light pattern? Also are there any heating problems/lens discolor with installing higher lite/power bulbs in the enclosed light areas of the 2005 Mustang?
Mike
Old Sep 3, 2005 | 08:48 AM
lwing18's Avatar
I don't know how to link to previous post , but there was talk about nokya bulbs.....per the following (post preview #424954)
Here is the response I received from the vendor of the Nokya bulbs. Interesting read:
Mark,
The Nokya Arctic White H13 bulbs are a Stage I bulbs, which means they
use a stock wattage draw and don't produce a significant heat increase.
Many cheaper aftermarket bulbs use a higher wattage bulb to obtain
increased light output, however Nokya, and all of the aftermarket bulbs
that we carry use a more efficient gas mixture, and a Xenon-Halogen
blend is able to increase light output while drawing stock wattage, and
significantly increasing light output.
As with any aftermarket lamps, it's a good idea to check see how they
react with your system - if you turn them on and check immediately how
the wires a few inches back from the headlights feel you'll know right
away if it's too much for your stock headlight harnesses. I have yet to
hear our H13 customers experiencing melting harnesses or blown fuses -
but if it's something you're concerned about it's a good idea to check
the wires just to have peace of mind.
If you look on just about any web forum, where aftermarket lighting is
mentioned - there's always at least someone who says to stay away and
NEVER purchase aftermarket lighting, because it's too hot for your
system. I can tell you that after selling several thousand Nokya bulbs,
and MTEC bulbs, we have had 2 customers tell us that the headlights
damaged their headlights from overheating - and both were using plastic
aftermarket headlights that are made with much less lower quality than
OEM materials.
Hope that helps!
Ryan Snell
SCS International, Inc.
RCooke08GT
Feb 19, 2017 03:03 AM
mmb0329
Oct 1, 2015 10:59 AM
Fedupdave42169
Sep 30, 2015 08:45 PM
