H13 bulb replacement
Old Feb 1, 2007 | 12:46 PM
mikes rx's Avatar
Quick question: I just replaced my Xtra Visions with Silverstars, and I had TWO gaskets come off with each bulb when I removed them. Can anyone verify this?
the new bulbs have the ONE gasket attached...could I have left the original bulb's gasket in the housing when I replaced factory to Xtra Vision (ie-when I pulled out the factory bulb, I left the gasket on the back of the housing by accident and didn't realize it)
Or should there be TWO gaskets (one for the bulb, and one for the back of the housing).
Here's a pic of what was removed: you can see two separate gaskets from the gaskets that I put on the bulbs themselves (note, there are two bulbs, and two additional gaskets)
Old Feb 1, 2007 | 01:23 PM
mrkabc's Avatar
There should only be one gasket. It looks like your OEM gaskets stayed in your housings.
Old Feb 1, 2007 | 01:25 PM
mikes rx's Avatar
That's what I'm thinking too. But, I've had no issues with having two gaskets (had it like that for a year), except that it was a little harder to remove them just now, and to put the new ones on. I'm thinking about putting the second gasket back??? It seems "wrong" not to
Old Feb 1, 2007 | 03:41 PM
70MACH1OWNER's Avatar
I agree!! One only.
Old Feb 1, 2007 | 04:16 PM
Northwest GT's Avatar
That's all I had in mine. One gasket.
Old Feb 1, 2007 | 04:30 PM
mikes rx's Avatar
I must have left the gaskets from the factory bulbs in when I put in the Xtra vision. But weird that I would have done it on both sides
lakersfreak
Jun 13, 2022 12:29 AM
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
PonyMuscletang13
Sep 29, 2015 09:40 AM
