H10, H11, H13, what do they mean?
Old Aug 22, 2007 | 02:02 AM
jmanpatsfan's Avatar
I have been researching HID conversions, but what do H13, H11, H10 correspond to?
Old Aug 22, 2007 | 02:16 AM
BeavGT's Avatar
The bulb type .. or design or actual physical size to fit the housing. I believe H13 is the main headlight. H10 is the stock GT fog light. And H11 is the V6 fog light. Hope this helps. I really have no idea what you are looking for and now im rambling cause its 4:16 am.
Old Aug 22, 2007 | 10:15 AM
So it corresponds to the bulb size, thank you that is all I was looking for.
Old Aug 23, 2007 | 12:27 PM
RedDragon777's Avatar
true, H13 is the headlight size for all the mustangs, H10 for the GT fogs, H11 for the V6 and i think the GT500 uses the same for its fogs
Old Aug 23, 2007 | 12:58 PM
buffguy's Avatar
I bought the Wrong set for the gt fog, H11 instead of h10. Do you think it would fit?
Old Aug 23, 2007 | 02:40 PM
buffguy's Avatar
For some reason on Sylvania's web site, they state that the gt fogs are h11 . http://www.sylvania.com/ConsumerProd...RG-Results.htm
2006 FORD Mustang
Fog/Driving light
9145
9145ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H11-55W
Old Aug 23, 2007 | 03:18 PM
that is odd, because i pulled my grill earlier and looked and it said H10 on the back of the bulb
Old Oct 1, 2007 | 12:12 AM
HapaJimmy's Avatar
There's also a wattage issue regarding H10's & H11's.
H11's tend to put out about 10w more than a typical H11.
For example the Sylvania Silverstar H10 (9145) is rated as a 42 watt bulb.
They don't have a Sylvania Silverstar H11 but a regular H11 from Sylvania which is rated at 55 watts.
Typically H11's run at a higher wattage meaning a little brighter given that all else being equal.
Why the diff between H10's & H11's probably due to the difference in surface area of the bulb housing. V6's being smaller surface are may require a higher wattage to produce a comparable beam pattern as a larger but lower wattage bulb from a GT fog-light.
Just my guess, I've got an 08 Vapor Metallic GT with HID's & I'm looking for some fog light bulbs to match more closer to my factory HID's without resorting to HID fogs. I decided to buy the Silverstar 9145's to give them a try and to see how they'll look. I'll let you guys know.
Old Oct 6, 2007 | 04:31 PM
06 Slvr Bullitt's Avatar
GT500 uses a PS24W bulb for the foglights. I believe Chevrolet uses this same bulb in either their Coloarado trucks or their Silverado trucks. I remember being on a Chevrolet truck site earlier in the year where some of the guys were complaining about the bulb choice Chevrolet decided to use for the foglights. At the moment, no third party company (including Sylvania) creates an aftermarket version of this bulb. When one blows, one will have to bite the bullet and order a replacement through their Ford parts department. Kevin had given me the part number, but I lost it...probably strewn about somewhere in my house.
Old Oct 9, 2007 | 09:53 AM
krnpimpsta's Avatar
The silverstars wont work.. they're way too yellow. In fact, all non-HIDs are too yellow. Here is a pic of a guy running Saleen HIDs with Silverstar fogs:
http://forums.bradbarnett.net/showpo...3&postcount=40
The 4300k fogs are a tad too blue, but the 4000k fogs are almost just right... see my before/after photos here:
http://forums.bradbarnett.net/showpo...3&postcount=46
$200 at StangMods. Great service/warranty/everything.
Old Oct 9, 2007 | 11:09 PM
HapaJimmy's Avatar
Those are a vast improvement over the factory fogs in comparison with the new factory HID's. Look great, I like those.
One question, are those plug n play? Or are there any splicing involved?
Old Nov 1, 2007 | 03:05 AM
metroplex's Avatar
What HID conversion kit will i need for the H10 foglights? Will ones designed for 9005, 9006, or H11 work?
Good Times
Aug 29, 2015 10:18 AM
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
