"Fader" Style Door Sill Side Stripes
I'm trying to locate the "Fader" Style Door Sill Side Stripes like the ones that come from the factory on 2003 - 2004 Mach 1's.
Can't seem to find them online anywhere.
Anyone know where I can purchase them from ??
They fad from about the rear of the door to the rear wheel opening.
Any other suggestions ???
The Analog Admin!
Received 2,992 Likes
The Problem with Putting These on an 05 is they are Cut in three Pieces to an 04 Body Style. The Lengths would be different. If you contact Grapics express Maybe they Could Custom Make you a one Piece Set.
kc
kc
kc
kc
kc
kc
kc
kc
I called Graphic Express. The lady said they did not offer any type of "Fader" stripes that looked like the factory 03 - 04 Mach 1 stripes.
I'm not totally concerned with them going from front wheel well to rear wheel well. I planned to cut off the "Mach 1" lettering and they could be short - sort of like the "Steeda Sidewinder" stripes.
Any other suggestions - Anybody ???? THANKS IN ADVANCE !!!!!!
The Analog Admin!
[attachmentid=24351]
I am Going by The Picture which appears to have cuts. It may be one piece. I would check on the Pre05 site and see if any mach 1 Owners have replaced their Stripes.
kc
kc
That picture would make me think it's 3 pieces as well, but I just don't see that being very practical. I'm pretty positive that the graphicexpress side stripes are all one piece though.
LOL... I understand that. I'm saying that the stripe comes in one piece. You install it as one piece with the door closed, so that it is straight across. Then, you cut the stripes right where the gaps are between the door and the fenders. If you get the stripe in three pieces, even if it's all layed out on one piece of backer paper to make sure you intall all 3 pieces straight, you'd have to sit there and try to line of the cut lines with the doors, which would not be an easy task. The vinyl is going to shift a little anyway when you start to squeegie it.
I have ordered 2 different side stripe kits from graphicexpress and both came in one piece. But obviously you would need to cut it at the doors yourself prior to opening the doors. I thought that was understood and was why I didn't say it.
Originally posted by 2Slack@June 13, 2005, 4:34 PM
It has been a long day at work, I had to mess with somebody!![Biggrinjester](https://themustangsource.com/forums/images/smilies/biggrinjester.gif)
![Lol](https://themustangsource.com/forums/images/smilies/lol.gif)
The Analog Admin!
Originally posted by 2Slack@June 13, 2005, 12:42 PM
The strip has to be in 3 pieces for the door to open.
