Dumb blonde question/gas cap emblem
Old Nov 30, 2007 | 02:21 PM
MustangLynda's Avatar
How do I get the gas cap emblem off my trunk?
Old Nov 30, 2007 | 02:22 PM
ShowGT's Avatar
Heat, fishing line and some patience. There will be 2 locator tabs in the middle along the sides Lynda. A piece of cake
Old Nov 30, 2007 | 02:59 PM
backafter20's Avatar
Several strands of dental floss will work if you don't have fishing line. Then you'll need some sort of residue remover for the left-over adhesive. You do know that you'll be left with two holes if you're not intending to put something in it's place, don't you?
Old Nov 30, 2007 | 03:13 PM
I figured what would be left wouldn't be pretty! I want to change it and really don't want to have to pay someone to do it if I don't have to. On the other hand, I didn't have the nerve to just pull it off without asking someone first either.
Thanks you guys.
Old Nov 30, 2007 | 09:45 PM
ShowGT's Avatar
Lynda, If I was close to you, you would be more than welcome to come by our shop and let one of us take care of this issue. I could have you in and out and say 20 minutes.
Old Nov 30, 2007 | 10:01 PM
05GT-O.C.D.'s Avatar
I lust for a M24
Isn't there a button in the car to open that gas cap? It's right next to the button for the trunk release.
Old Dec 1, 2007 | 04:17 AM
bald-guy's Avatar
PLEASE be careful,,, this is what happens when you apply too much heat,
Ron
Old Dec 1, 2007 | 05:08 AM
Supercharger's Avatar
Yeah, I would avoid the heat, just use the fishing line or floss. As to removing the gluey residue, just use your fingers. You have to be persistent because it takes a while and don't use anything sharp or abrasive.
Old Dec 1, 2007 | 08:14 AM
You have no idea how much I wish someone like yourself was local here. I would even consider some mods if that were the case.
I am reasonably mechanically inclined but have never been taught/learned jack about cars. Very frustrating!! I am perfectly willing to tear my house to pieces even if I end up paying someone to put it back together, but my car, no way.
Old Dec 1, 2007 | 08:16 AM
Ron
Yeah that scares me...
Old Dec 1, 2007 | 08:17 AM
Um, where is it you say?
Old Dec 1, 2007 | 11:38 AM
boss429man's Avatar
I used a large plastic scraper and a blow dryer.
Old Dec 1, 2007 | 11:40 AM
Juice's Avatar
Use Goo-be-Gone to remove the tape residue. When I removed my GT emblems, that worked great.
Old Dec 1, 2007 | 11:48 AM
MrMojo1953's Avatar
Thanks for posing this question, Lynda.
This is exactly the project I've got in mind for my car this weekend...
off with the GT badge, and on with the FORD/Shelby Snake badge.
As far as the heat thing... where to direct the heat? Along, and around the edges? Or just criss-cross back and forth across the whole surface?
Old Dec 1, 2007 | 01:13 PM
boss429man's Avatar
Side gt emblems come off easy, didn't use heat. be careful not to scracth paint.
Old Dec 1, 2007 | 07:50 PM
GT Bob's Avatar
Heat isn't a problem if you use a blow dryer as opposed to a heat gun. Blow dryer and dental floss works very well. Goo gone works very well on all of the adhesive leftover.
Old Dec 1, 2007 | 08:17 PM
Larmo's Avatar
Lynda, what do you plan on putting in its place?
Old Dec 2, 2007 | 06:47 PM
I saw one I liked that was black with just a pony on it. I have since lost the link though, but with a little patience I'm sure I'll find it again! I wanted to make sure I could get the old one off before buying the new one
I'm also going to keep the old one if I don't destroy it in case I can't stand the '08 painted one (WTF?!). At least I can use it until I pick another one for that car...
Old Dec 3, 2007 | 05:23 AM
Mach's Avatar
On my 06 I used one of those little "bent" flatblade screwdriver tools to remove the entire medallion. Marcello (of Silverhorse) said that if you gently pry near the keyhole, it will pull right off. I took his advice and it works perfectly. It leaves the adheasive tape in one peice and allows it to be reused. I do recommend doing it when it is warm as the tape will be more likely to release without tearing.
Hope this helps, here is mine with replacement medallion.
Attached Thumbnails Dumb blonde question/gas cap emblem-dsc00062a.jpg
Old Dec 3, 2007 | 07:47 AM
I wondered if I could "lift" it off, being careful of the paint of course. At least now I know how it's on there to begin with, which help a great deal!
