Do i need shocks and struts?
Am I going to lower my GT one inch all the way around, and was wondering if I should order the tokico Hp shocks and struts to go along with it. Are those really needed for such a small drop?
You have the original 7 year old shocks on there now? Then definitely need some newer/better ones. If not, you can wear out your current ones while you wait for the ride to deteriorate enough to replace them. Of course, that means tearing apart the MacPherson strut in the front again to replace the shock...
How many miles you have total?
I just pulled out my Vogtland GT springs, Tokico D-spec shocks, replaced with coil-overs and adjustable perch springs in the rear, suspect mine still have some life in them...
Originally Posted by Clark Kent
Yeah that's what I've been hearing. That once I'm in there I might as well do everything. My car is seven years old, but only had 60 k on it.
Originally Posted by B1GP1MP1N
I should have upgraded my shocks and struts when I lowered mine. If you've got the cash I say do it. Save the headache of tearing it apart again later.
Did you notice a significant difference from stock because you didn't?
Just proves you haven't tried the Konis yet
I have a full set of adjustable D-specs sitting in my garage, will sell them for cheap! Less than 20k miles on them.
They're just not the quality of the Koni, and warranty coverage sucks.
However, Tokico anything is better than stock or any bargain brand at the local AutoZone.
robjh22
Sep 8, 2015 12:31 PM
