CS-6 hood arrives....funky
Old May 18, 2007 | 12:25 PM
Faber's Avatar
Just wondering if it is normal to have to grind half an inch to an inch of material off of a hood to get it to fit? I got a call from my body shop and they want $500 to grind and prep this hood. Is this a normal thing, or is this hood just a friday quality control issue?
Old May 18, 2007 | 12:28 PM
RobDurham's Avatar
From all the parts I have seen that’s typical for any of Shelby’s fiberglass parts.
You should see their Cobra parts in their raw form.
Old May 18, 2007 | 01:00 PM
GPStang06's Avatar
If you are refering to the front of the hood, yes, mine had it as well but that just was to get the front across the grill to line up with the fenders. As far as the back goes by the window, I had to shim mine (under the hoos struts) otherwise it rubbed up against the platic guard housing the windshield wipers.
Is the $500 just to prep the hood or does that include paint, clear, and buffing too?
Old May 18, 2007 | 01:52 PM
5150PONY's Avatar
WOW...1/2 inch is way too thick....if you grind it down to 1/2 inch, then the hood must be really thick....
How thick is your hood after you had grind it down 1/2 inch? Because that is alot of fiberglass....
Old May 18, 2007 | 04:57 PM
GPStang06's Avatar
The hood is almost a half inch thicker but the inner layer is made from the same stock layer. Under the hood itself you may have issues with roots/twinscrew style super chargers or a strut tower brace. Your CAI should be fine.
Old May 18, 2007 | 05:24 PM
ShowGT's Avatar
I would call whoever you bought the hood before I spent that kinda of money. My Cervini hood came off the truck, out of the box, onto the car for a trial fit and into the paintbooth for curing and primer.
Old May 19, 2007 | 01:35 AM
nickpurcell's Avatar
that sounds about right if the 500 includes paint. my hood needed a lot of work to make it look right. the had to cut off the front part to make it line up with the fenders like gary said. after i picked up the car after paint i had to send it back to get it redone and repainted because there were still many imperfections but all the headache was well worth it. but now it is very much stock looking.
Old May 22, 2007 | 05:29 PM
Faber's Avatar
nope. the 500 is just to fit this hood. it is so rough around the edges that it is gonna take alot of hours to get it ground to fit.
Mar 30, 2021 09:29 AM
yabutt
Oct 23, 2015 01:05 PM
TerryD
Sep 28, 2015 11:48 AM
seaclam
Sep 25, 2015 01:29 PM
tbear853
Sep 8, 2015 11:18 PM
