Burnt sequential harness
Old Sep 23, 2009 | 03:14 PM
Antigini-GT/CS's Avatar
Founding MOTM
Committee Member
Anyone here with sequentials, specifically CDC look at your harnesses lately? A bulb went out so I changed it and noticed the harness as well as the bulb housing was burnt. Is this common?
Old Sep 23, 2009 | 04:06 PM
colbymh's Avatar
Yikes.....Id be making some calls.
Old Sep 23, 2009 | 08:12 PM
ManEHawke's Avatar
depends how bad.
Most burnt bulbs I've changed usually have light browning near the socket. Never crispy black lol
Old Sep 23, 2009 | 08:27 PM
Founding MOTM
Committee Member
Originally Posted by ManEHawke
depends how bad.
Mine are burnt but not crispy! It looks from a little discoloration to burn. I'll snap a pic and post it of the bulb. That harness is too **** hard to get to with my sub box in the way.
Old Sep 23, 2009 | 08:30 PM
I agree with ManEHawke...
I changed a taillight bulb on the F150 just last month and while I expected it I was still surprised by the black/brown char on the socket. Probably just normal. As long as its not melted.
Old Sep 24, 2009 | 12:56 PM
Founding MOTM
Committee Member
Okay, I looked at the pic again and it looked worse the first time than how it does in this pic but that's probably me just being paranoid. What did strike me as weird was not only THIS bulb was burnt in this way, but also the other bulbs AND the harness connecting piecing.
I haven't checked the left side yet since none of those bulbs have burnt out. By what some of you are saying this is normal? I shouldn't worry until I see black?
Old Sep 24, 2009 | 03:44 PM
Mine actually looked worse. This is normal. The OEM sockets in my F150 and my Expedition look this way. I was surprised, but once I saw it in all my cars I figured it must be normal. It's just from the heat of the bulb when it was burning. Not the result of a short or anything like that. If there was something really wrong the fuse would blow. IMHO
If its melting th plastic, then there could be a problem.
Old Sep 25, 2009 | 07:27 AM
houtex's Avatar
Normal. No worries. Cheaper plastics, brake lights, high temp filaments=browning. If you wanted, flip them upside down so that the less burnt part is the one getting crispy.
The biggest concern is *not* the surrounding piece that hold it up. That little tip end isn't a big deal, it's just gettin' baked, and unless you're going to be playing with it a *lot*, it won't do anything The sides down the way aren't getting baked either, so the light will be aligned just fine.
As long as the contact areas themselves aren't getting crispy crittered, the socket is fine, although I would like to see how that burnt tip looks on the inside, just to see.
/Go check out 95-98 Thunderbird CHMSL sockets. THAT's a fire to happen one day (tm)
duppycat
Feb 16, 2019 08:36 AM
jim010
Sep 14, 2015 10:15 PM
JonathonK
2012-2013 BOSS 302
14
Sep 3, 2015 08:37 PM
