Anyone use a 3157 LED in the front bumper lights?
Old Oct 7, 2007 | 09:45 AM
MTAS's Avatar
Question Anyone use a 3157 LED in the front bumper lights?
I have clear corner/bumper lights up front and am curious if anyone running the same setup but using a 3157 LED light. If so, which brand did you go with? Any up close pics from the side and from would be appreciated too.
Old Oct 8, 2007 | 11:04 AM
jcthorne's Avatar
I tried the led replacement lamps for those and the smart junction box did not like them at all. Installed clear conventional bulbs in the corner lamps for now. Surely someone makes an LED replacement that is compatible.....
Old Oct 8, 2007 | 05:08 PM
MTAS's Avatar
An LED bulb that replaces a dual-filament standard bulb, such as the 3157 used in front turn signals and brake lights, requires either a resistor placed in parallel to simulate the load of a standard bulb, or a special flasher that will accomodate LED bulbs that need to flash.
Ecostang
Nov 3, 2022 08:50 PM
Chip
May 10, 2018 12:57 PM
robjh22
Custom Vanity Personalized License Plates & Brackets /Delete Brackets
14
Nov 1, 2015 11:28 PM
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
mustangfan410
Aug 5, 2015 03:00 PM
