$25.00 trunk tool storage solution
Old Mar 8, 2008 | 11:11 AM
partsbill's Avatar
wanted a place to store a few tools in the trunk where they wouldn't be in the way, and also didn't want to spend the money for the Roush tool kit ($275.00), this is the what I did.
Old Mar 8, 2008 | 11:44 AM
Northwest GT's Avatar
Looks good, but what is the tool kit/where did you get it? And, I can only guess that it is screwed into the trunk lid. Velcro sure ain't gonna hold it
Old Mar 8, 2008 | 01:01 PM
partsbill's Avatar
Started out by tracing the interior surface of the trunk with some butcher paper and transferred the shape that I liked onto some poster board and cut it out. Layed the poster board on hardboard ($5 Home Depot) and cut my shape out (had to cut a notch for the brakelight wires that come off the lower right edge of the trunk.
Temporarily mounted to trunk by removing clips for brake wiring and drilled a matching 1/4" hole on the left brace of the trunk. Used plastic push pins from local auto supply to secure. Trimmed a few spots after this that were rubbing and smoothed the shape a bit.
Now to the indoor work...
Picked up a small tool box from Sears(about $8) and drilled two 1/2" holes in the lid where it will eventually mount to the trunk lid panel.
Now, , I closed the bottom of the box, so that it is now upside down, and attached a GT logo to the bottom of the toolbox, so that it will be right-side up when I attach this to the trunk panel.
Heres the hardware I'll use to attach the box to the panel. 6 Large 1/4" washers, 2 1/4" x 1" bolts, 2 1/4" lock washers, 2 1/4" nuts, and 2 1/4" wingnuts.
Went to the local car audio shop and bought some speaker box carpet (almost identical to charcoal trunk carpeting) for $10.00. Used spray adhesive to stick the carpet to the hardboard, and wrapped the board, using hot glue to secure the edges.
From the back side, stick the bolt through a washer and mount through the panel for both inner holes.
On the front side, place a washer, lock washer, and nut on each bolt and tighten.
Toollbox holes should match up to the bolts coming through.
Place a washer, and secure each bolt with a wingnut.
Close up the box and you're ready to attach to the trunk!
From here, you match up the holes in the panel to the holes in the trunk bracing and push in the plastic retainer clips to secure. I ended up mounting the panel with 5 push pins, 2 on the top and 3 on the bottom just to make sure it was secure. I think it finishes off the trunk really well, and I can remove the tool box by loosening the wingnuts if I need to use it.
Bill
I already had the tools, (multi-bit screw driver/adjustable wrench/needle nose pliers/adjustabe pliers).
Old Mar 8, 2008 | 03:03 PM
n8rfastback's Avatar
im gonna have to do something like this... i hate my tool box sliding around my trunk all the time...
Old Mar 8, 2008 | 04:50 PM
BossDawg's Avatar
That is really cool, nice work! That would be good for tools or car show detail supplies.
Old Mar 9, 2008 | 01:51 PM
Larmo's Avatar
Links to pics broken???
Old Mar 9, 2008 | 09:24 PM
krnpimpsta's Avatar
nice work! where did you get the GT & pony emblems?
Old Mar 10, 2008 | 05:18 AM
partsbill's Avatar
I had a spare GT emblem that I had bought a year ago for my manifold cover that I didn't use, the ponys are hand painted.
Old Mar 10, 2008 | 09:05 AM
what do you need the tools for?
Old Mar 10, 2008 | 10:51 AM
partsbill's Avatar
haven't needed them yet, but if I ever do I'll have them.
trackpack13gt
Jul 25, 2017 05:29 PM
TMDM
Sep 24, 2015 07:00 PM
