18" rims on back 17" on front
Can you put 18's on the back and leave the 17's on the front without messing up the traction controll and abs. And i am assuming the dia of the 18" tires will be larger than the 17's. Anyone try this
<div class='quotetop'>QUOTE(mark221 @ March 5, 2006, 4:12 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
It could work, but you'd have to play with the tire sizes/aspect ratios to get the total diameter very close.
It will likely unbalance your handling as one set will tend to break loose in a corner at a different rate than the other
[/b][/quote]
The Ford GT is designed for different diameter tires in the front and back too though. The axles are set at different heights...
I say you could, but you'd be losing sidewall if you wanted to keep the tires around the same diameter. You want about 4.5" on an 18" rim and 5" on a 17" rim.
RRRoamer
1/19/17 05:27 PM
forceflow2
'10-14 Interior and Audio
8/4/15 08:02 PM
