18" rims on back 17" on front
Old Mar 5, 2006 | 02:09 PM
mark221's Avatar
Can you put 18's on the back and leave the 17's on the front without messing up the traction controll and abs. And i am assuming the dia of the 18" tires will be larger than the 17's. Anyone try this
Old Mar 5, 2006 | 03:21 PM
Torch_Vert's Avatar
<div class='quotetop'>QUOTE(mark221 @ March 5, 2006, 4:12 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
It could work, but you'd have to play with the tire sizes/aspect ratios to get the total diameter very close.
It will likely unbalance your handling as one set will tend to break loose in a corner at a different rate than the other
Old Mar 5, 2006 | 04:53 PM
TURBO 05's Avatar
the Ford GT has 19" in the rear and 18" in the front, go for it!
Old Mar 6, 2006 | 12:01 AM
Enfynet's Avatar
The Ford GT is designed for different diameter tires in the front and back too though. The axles are set at different heights...
I say you could, but you'd be losing sidewall if you wanted to keep the tires around the same diameter. You want about 4.5" on an 18" rim and 5" on a 17" rim.
RRRoamer
Jan 19, 2017 05:27 PM
Mackitude
Aug 13, 2015 01:05 PM
forceflow2
'10-14 Interior and Audio
Aug 4, 2015 08:02 PM
whowasthat
Jul 19, 2015 01:49 PM
