Tire Rotation
Old Apr 30, 2006 | 08:22 AM
05BlackVert's Avatar
I put some GT wheels and tires on my car about 5k miles ago.
Am I correct in assuming they are not directional and all I need to do is swap the fron and back tires?
Thanks...
Old Apr 30, 2006 | 08:23 AM
rygenstormlocke's Avatar
<div class='quotetop'>QUOTE(05BlackVert @ April 30, 2006, 10:25 AM) Quoted post</div><div class='quotemain'>
Thanks...
[/b][/quote]
Yes, you are correct.
Old Apr 30, 2006 | 10:41 AM
scrming's Avatar
for non-directional....
http://www.carcare.org/Tires_Wheels/rotation.shtml
Old May 2, 2006 | 05:40 PM
Thanks for the help guys...
Old May 2, 2006 | 05:48 PM
199's Avatar
199
its also in the manual, remmber to tell them to use a torque wrench when screwing the lug nuts back on, also info on that on the manual, i just rotated my tire 10,000km
Old May 2, 2006 | 07:38 PM
Thomas S's Avatar
<div class='quotetop'>QUOTE(199 @ May 2, 2006, 6:51 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
A torque wrench, really? I get mine pretty tight, never used a torque wrench for that.
Old May 2, 2006 | 07:46 PM
karman's Avatar
<div class='quotetop'>QUOTE(BlackLX4.0 @ May 2, 2006, 9:41 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Be careful to do it evenly. There is a possiblity of warping the rotors especially if they are hot.
Manual does recommend a torque wrench.
Old May 2, 2006 | 07:49 PM
Thomas S's Avatar
<div class='quotetop'>QUOTE(karman @ May 2, 2006, 8:49 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Well i tighten them slowly, every other nut. I snug them first, then tighten, then once more around to make sure.
Old May 2, 2006 | 07:50 PM
199's Avatar
199
the torque wrench gives you the right amount needed,, to screw the lug nuts, they are much better than the powered equipment that can over screw the nuts and with time damage the lug nuts. (the drill like tool that is used to tighten)
Rando
Aug 25, 2021 11:12 AM
cozyp828
Apr 18, 2016 09:46 PM
