Steeda Strut Tower Brace
Old Jan 6, 2006 | 02:14 PM
  #61
Thomas S's Avatar
Originally posted by AvtoLubitel@January 6, 2006, 8:30 AM
This is rather funny in a sad kind of a way. I have about 1.5 inch between the brace and the hood, but it rubs against the engine block. Mine is also going back as well. :cry: I tried driving with it and it improves handling noticeably. Not drastically or anything, but noticeably. I have a V6. Now, assuming they are made to the same spec it might be they they don't fit either V6 or GT well. I guess good thing is that they are essentially handmade, so the clearance will vary a bit from one to another. They are not very expensive, so it is worth trying them again I would say.
Have you tried using a couple of extra washers to raise it slightly?
Old Jan 15, 2006 | 09:25 AM
  #62
AvtoLubitel's Avatar
Sorry for the delay in responding - I just came back from vacation. To answer your question, it was the first thing I thought about. Unfortunately after the strut brace is on there is not enough thredding on the bolt left to put the nut on after a washer is under the brace. On the bright side the seller was very good and refunded me the money I paid.
Old Jan 21, 2006 | 11:03 AM
  #63
ex-Galaxie500's Avatar
Well, I got my refund from and am ready to try a different mod.
As an aside, I highly reccommend buying from MustangTuning.com as they have excellent customer service and were very helpful (much better than my experience with Steeda) and gave me my full refund and didn't charge me the restocking fee, etc.
Old Mar 4, 2006 | 01:34 PM
  #64
islandmustang's Avatar
any luck out there with a quality fitting strut tower brace??
Old Mar 4, 2006 | 01:36 PM
  #65
timgriffeyfan's Avatar
Nope. I just fit a few "spacers" under the one I have & it gives JUST ENOUGH clearance.
Old Mar 4, 2006 | 02:11 PM
  #66
<div class='quotetop'>QUOTE(timgriffeyfan @ March 4, 2006, 3:39 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Are you saying your steeda brace was rubbing on the engine cover? I thought they were rubbing on the hood liner?
Old Mar 4, 2006 | 02:12 PM
  #67
mine was the Dallas Mustang one & it was rubbing on the engine cover.
Old Mar 5, 2006 | 09:38 AM
  #68
I see. Thanks!
Old Mar 8, 2006 | 08:42 AM
  #69
StupidTodd's Avatar
I have a STB (one of the $50 ones off Ebay)...
And, man, is it close.
When I first installed it, I thought all was well, but at higher rpms, I could hear a weird buzz. I checked, and the engine rubbed against the brace ever so slightly. Luckily I have a hydraulic pipe bender, so I started making minor adjustments.
Finally, I did manage to get it up off the engine, and just barely touching the engine liner. There's probably 1/16-1/8th clearance over the engine.
If these things flex even a little bit in shipping, they're going to be off. The fit is just too tight.
I do however love the brace. It makes cornering so much more enjoyable (and safe too).
Sep 30, 2015 07:02 PM
GeoWett
Sep 30, 2015 06:40 AM
RoushRS3
Sep 29, 2015 08:03 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
Sep 24, 2015 08:15 PM
