Short throw V6 shifter?
Old Mar 14, 2007 | 04:23 PM
Airwolf's Avatar
I'm looking for a good short throw V6 shifter, we have tried the steeda sport shifter, but it didn't do much. And the hurst has a very non-stock look to it. Are there any other options?
Old Mar 14, 2007 | 05:22 PM
GRAYPNY's Avatar
Check Pro 5.0 Paul. Not sure if they offer one for the V6 but I like my GT one.
Old Mar 14, 2007 | 07:53 PM
subzero05's Avatar
With our Hurst unit, you can change sticks to one that you like. There are many different stick choices you can use in the Hurst catalog. I know atlanticspeed.com is running a good special on the V6 hurst shifters right now. Or, if I can help you further just let me know
Old Mar 15, 2007 | 09:02 AM
Airwolf's Avatar
Is there any way to use the hurst with the stock shift boot and ****?
Old Mar 15, 2007 | 09:07 AM
subzero05's Avatar
Sure you can use the stock boot. The thread pattern on the stock **** is the same as the Hurst thread pattern, but honestly I don't think it would look right with the stock **** on there.
Old Mar 15, 2007 | 09:38 AM
Airwolf's Avatar
Well, using the stock boot and shift ****, it will look exactly like a stock shifter, just with the hurst underneath, thats what we are going for. Am i correct?
Old Mar 15, 2007 | 11:53 AM
subzero05's Avatar
Yeah you could do that. The Hurst stick is designed to be exposed with the gromment that comes with the shifter to hold the boot in place. But, I suppose you could just put the boot back up in its original location and it should be fine
Old Mar 15, 2007 | 03:45 PM
nonstopred's Avatar
no the hurst stick is longer...you would just need to use the stock stick and boot/****
Old Mar 17, 2007 | 06:10 PM
Airwolf's Avatar
The chrome hurst stick does not work with the stock ****. The shorter black hurst stick works, but its a shorter stick.
Old Mar 18, 2007 | 07:38 PM
subzero05's Avatar
you are correct. The hurst stick works with the Hurst ****, not the stock one.
Old Mar 25, 2007 | 06:22 AM
spooky's Avatar
so the GT does have a different shifter than the V6? i test drove a GT the other day because i've never been in one. the shifting was the first thing i noticed. i liked it better than my V6 and wanted something like that.
Old Mar 26, 2007 | 07:12 AM
boomerman's Avatar
Could the shifting feel be different since the GT uses a different transmission?
I added the Saleen short shifter block to my stock shifter on my V6 and it helped it out alot.
I like the look of the factory shifter but it still did not have the feel I was looking for.
I finally switched the shifter out to the Hurst and I am glad I did.
trackpack13gt
Jul 25, 2017 05:29 PM
Jul 8, 2016 08:53 AM
yabutt
Oct 23, 2015 01:05 PM
Sep 16, 2015 06:44 PM
