reat sway bar
I assume your Mustang is a V-6 ? Anyhow It certainly wouldn't hurt to use a GT sway bar, but if you plan on lowering your car by 1.5 inches or more in the rear ? Then you should also look into upgrading to an adjustable panhard bar as well !
If you put a GT bar in the rear of the V6 and do not put the GT one on the Front it will not corner right. It might under steer like crazy. I had an older camero once and put a TransAm V8 sway bars on My V6 Camero and it Handled fantastic.
You can probably find take-off parts from GT or GT500 owners that upgraded.
According to Ford Racing, they are the same kit, from 2005-2014. Here is the link showing. It does say it doesn't fit the V6 models, but if you are buying a used take off, it will have all the parts and pieces to make it work. The rear and front do fit. I have 2008 Bullitt sway bars on my 07 V6. I just put in an 8.8 with 3:73's and LS, and used the set up from the Bullitt. It fit without any problems. It will fit, but you do have to have all the parts and pieces.
Here is a link.
http://www.americanmuscle.com/frpp-s...it-0513gt.html
Here is a link.
9/16/15 07:44 PM
robjh22
9/8/15 01:31 PM
