reat sway bar
Old Apr 16, 2015 | 08:55 AM
silverstang417's Avatar
reat sway bar
Does an 07 mustang come with a rear sway bar and is it a good idea to buy one if not.
Old Apr 16, 2015 | 10:14 AM
it does come with one. If it doesn't have one because someone took it off I would get one installed.
Old Apr 16, 2015 | 10:52 AM
Would a gt sway bar be better than the one I have now
Old Apr 16, 2015 | 11:34 AM
m05fastbackGT's Avatar
I assume your Mustang is a V-6 ? Anyhow It certainly wouldn't hurt to use a GT sway bar, but if you plan on lowering your car by 1.5 inches or more in the rear ? Then you should also look into upgrading to an adjustable panhard bar as well !
Old Apr 16, 2015 | 01:19 PM
Jazzman442's Avatar
If you put a GT bar in the rear of the V6 and do not put the GT one on the Front it will not corner right. It might under steer like crazy. I had an older camero once and put a TransAm V8 sway bars on My V6 Camero and it Handled fantastic.
Old Apr 16, 2015 | 01:42 PM
Enfynet's Avatar
You can probably find take-off parts from GT or GT500 owners that upgraded.
Old Apr 17, 2015 | 07:02 AM
or even in the junk yard for less
Old Apr 25, 2015 | 06:24 AM
Jek57's Avatar
If your is the base v6 it did not come with one.I just put a Gt sway bar on my 09 bought front and rear from newtakeoff parts made a big difference when cornering .Well worth it
Old Apr 29, 2015 | 09:47 AM
I found a rear and front sway bars but they can off an 2010 gt mustang now will they work on my mustang Cuz it says it fit 2010 to 2014 mustang but I was just wondering
Old May 24, 2015 | 10:51 PM
akdoggie's Avatar
According to Ford Racing, they are the same kit, from 2005-2014. Here is the link showing. It does say it doesn't fit the V6 models, but if you are buying a used take off, it will have all the parts and pieces to make it work. The rear and front do fit. I have 2008 Bullitt sway bars on my 07 V6. I just put in an 8.8 with 3:73's and LS, and used the set up from the Bullitt. It fit without any problems. It will fit, but you do have to have all the parts and pieces.
Here is a link.
http://www.americanmuscle.com/frpp-s...it-0513gt.html
bones302
Oct 7, 2015 04:42 AM
RoushRS3
Sep 29, 2015 08:03 PM
Evil_Capri
Sep 25, 2015 12:56 PM
Sep 16, 2015 06:44 PM
robjh22
Sep 8, 2015 12:31 PM
