P1744 Trans Diagnostic code?
Old Aug 8, 2005 | 07:30 PM
Mudman88's Avatar
Posted this in the laundry list thread (Laundry List) but thought I'd ask about details of this code if anyone happens to know what it really means.
My OD off light was flashing when I would get on the freeway so I took it to the dealer and they got a trans diag code of P1744. They called hotline and was told to reset, test drive and check again. They did and got all clear so they didn't do anything. :bang:
I'm curious if anyone has info on what code P1744 means???
Thanks in advance.
Old Aug 8, 2005 | 07:50 PM
05mustangV6's Avatar
Well according to my scanner reference manual the code P1744 is
P1744 Torque Convertor Clutch System Perf.
Thats all I got I will search for more info for you.
Found this P1744
Torque Converter Clutch System Stuck in Off Position.
Here http://www.redpulsar.us/~coldfusion/eecv.html
Old Aug 8, 2005 | 07:55 PM
Mudman88's Avatar
Thanks for looking into for me.
This is what the repair sheet says if it helps ya any.
"659 CONVERTER SOLINOID/VALVE WARR PERFORMED. TRANS ELECTICAL DIAG AND FOUND P1744. CALLED HOTLINE............., WAS TOLD TO CLEAR CODE AND TEST DRIVE..............TEST DROVE AND MONITORED PIDS AND CONVERTER IS OPERATING AS DESIGNED AT THIS TIME. REMOVED PAN PER HOTLINE AND CHECKED FOR CONTAMINATION AND NO PROLEMS AT THIS TIME. RERAN SELF TEST AND P1000. NO REPAIRS ATTEMPTED AT THIS TIME."
Old Aug 8, 2005 | 08:00 PM
No problem, wish I could tell you more but this is all I have. Hopefully a Ford tech may jump in and tell us what this means.
Old Aug 8, 2005 | 08:04 PM
Mudman88's Avatar
Originally posted by 05mustangV6@August 8, 2005, 9:53 PM
Found this P1744
Hmm, wonder if I have a bad/going bad torque converter. I'm not to up to date on newer cars systems, does the converter solinoid/valve have something to do with the converter clutch system?
Well thats a great place to start at least, I'll have to bookmark that page for future reference. Thats exactly what I was needing for starters.
Old Aug 8, 2005 | 08:07 PM
Fazm's Avatar
I would say check the fluid level, but we all know thats not possible, if its low, the conv clutch could be slipping. But regardless, just run it over to the dealer.
Old Aug 8, 2005 | 08:13 PM
Well thats a great place to start at least, I'll have to bookmark that page for future reference. Thats exactly what I was looking for starters.
I imagine it does, but not being a tech on the newer electronic transmissions I cant say for sure. Being that it references stuck though I would definitely say its an issue with a solinoid or switch in the valve body. Hope someone that knows for sure will chime in.
Mar 30, 2021 09:29 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
boz
Oct 1, 2015 04:47 PM
haitham
Sep 8, 2015 12:52 PM
