One GT Takeoff?
Old Aug 19, 2006 | 11:10 AM
Airwolf's Avatar
One GT Takeoff?
I managed to get ahold of some GT takeoff mufflers for free, so i've got two of those sitting in my garage now. My question is, without alot of crazy work, can i just jack the car up, unbolt the current v6 exhaust and attach the left hand side GT exhaust, so i can get atleast one on and see what it sounds like for awhile? I am assuming the pipe sizes are the same as i have not measured them yet, but i'm guessing someone has already done this so i would like your input, thanks.
Old Aug 19, 2006 | 01:10 PM
Cam07's Avatar
I put just one on for awhile until I got the second one installed. It's a very quick and easy install. The pipes are the exact same size.
Old Aug 19, 2006 | 11:21 PM
I-70 west's Avatar
Any noticeable performance increase?
Old Aug 20, 2006 | 04:56 PM
Zodiac's Avatar
there's been a SOTP increase reported by quite a few people, but then that could always be imagination and hopeful wishing... I dont know if anyone has dynoed it or not. I want to say that someone did but I cant remember for sure
Old Aug 21, 2006 | 03:39 PM
CHDS PNY's Avatar
whats the sound like?
Old Aug 26, 2006 | 11:20 PM
Airwolf's Avatar
I installed it last weekend, it has a slight sound increase, probably 30% or 40% louder than the stock exhaust. I think it might have a little better performance but that may just be my imagination because its louder.
Old Aug 28, 2006 | 02:51 PM
Kamicosmos's Avatar
I have a GT muffler on mine. Didn't even have to jack the car up to install it. I have the other muffler and the midpipes. Will i go dual? Doubtful. I don't think there is much performance gain with duals, and probably none with just the GT muf. It does sound nicer though, friends espcially really noticed the difference when I pull up to their houses. I also like it cause the Tip sticks out past the bumper a bit, makes it look more agressive.
Old Aug 28, 2006 | 04:23 PM
CHDS PNY's Avatar
does it sound ricey at all?
Old Aug 28, 2006 | 08:24 PM
Airwolf's Avatar
I havn't heard my own car from the outside while driving, but i stood behind it while it idled, and had someone rev it up a bit, it sounded like a small V8 and had what could be described as an "old" sound to it, very 60's ish, which is what i wanted. I'd say its a worthwhile upgrade. Does not sound ricey from the inside or outside form what i've heard.
Old Aug 29, 2006 | 07:11 AM
Dineau's Avatar
Anyone has a pic of a V6 with a GT exhaust, would like to see how far it sticks out from the bumper cover ?
Old Aug 30, 2006 | 05:39 AM
Racer3's Avatar
Here ya go. I have dual GT mufflers, but you get the idea.
Old Aug 30, 2006 | 07:05 AM
Dineau's Avatar
Would you have a pic from the side, showing how far it's comming out from the bumper. On those pics it's kind a hard to tell !
Thanks,
Old Sep 6, 2006 | 01:32 PM
swissdan's Avatar
May be this video, GT muffler on V6:
http://videos.streetfire.net/search/...0d2103c725.htm
Old Sep 6, 2006 | 06:16 PM
Dineau's Avatar
Thanks, that's exactly what I was looking for !
Was this your car ?
Did you found a noticable difference in sound compare the the V6 stock ?
Old Sep 8, 2006 | 08:00 AM
stngfever's Avatar
Intstalled the right side GT muffler last night. Install was fairly simple. Didn't jack the car up. I followed the directions from another post as follows:
1. Loosen clamp to exhaust
2. Unbolt all three hangers from car
3. Wiggle muffler until disconnected from pipe (helps to lift and twist)
4. Slide hangers onto GT muffler
5. Wiggle GT muffler onto pipe
6. Bolt both hangers to car
7. Check for clearance at bumper (mine was just touching at this point, therefore, I had to remove and bend both brackets up about 1/2")
7. Tigthen Clamp
I'm really happy with the results. I also took the time to paint the muffler flat black. I will get pics tonight and post.
Old Sep 8, 2006 | 11:42 AM
swissdan's Avatar
Was this your car ?
It's not my V6, I have installed a JBA axle back, big difference to the stock muffler; deeper, louder growl at idle and when accelerating nice agressive sound!
Do it! change your stock muffler, take what you want GT muffler, JBA, Mac, Ford racing, or whatelse and you won't return to your stock "sound" (if we can say sound )
Old Sep 9, 2006 | 05:55 AM
Racer3's Avatar
Sounds like you did a great job! However, I read in other forums/posts that the black paint might peel or melt - something about painting stainless steel...........
Old Sep 9, 2006 | 10:09 AM
stngfever's Avatar
Before and After Pictures:
Attachment 8915
Attachment 8916
In reference to painting, I used Flame Proof Header paint. I don't think it will be an issue.
Fred_Garvin
Sep 17, 2015 04:10 PM
Northwest GT
Jun 1, 2007 07:41 PM
esorense
V6 Performance Mods
Feb 10, 2006 11:40 AM
