i think my alternator is dead
Old Apr 17, 2008 | 10:43 PM
jcopin's Avatar
on the way home tonight i noticed my volt gague seemed low while doing a steady 70 on the parkway.
like halfway between middle and 0
maybe my stereo killed it? i just replaced the battery like a month ago
so i checked on my nav unit and it showed voltage at 10.9 .. i was like omg...
when i shut the car off it jumped to 11.9
any theories?
Old Apr 18, 2008 | 05:16 AM
Mach's Avatar
That is not right man. I would have it checked out today. If it dies off completly you may get more than you bargined for. Lotsa weird stuff happens.
Good Luck!
Old Apr 18, 2008 | 06:31 AM
jcopin's Avatar
im thinking the battery i got was defective..
on the way to work the voltage kept dropping.. hit 10 and everything shut off.. but the car still ran
guess il get a jump and have both tested..
any ideas?
Old Apr 18, 2008 | 09:28 AM
frdtch05gt's Avatar
Check to make sure it is charging. Use a voltmeter on the battery with the car running to check it. It very well could be the alternator. A friend of mine had the alternator go bad, it over-charged the electrical system, fried the battery and the pcm.
Old Apr 18, 2008 | 09:46 AM
slipnotovk's Avatar
bad batteries do happen. i would def get a volt meter on that thing and check it before it results in any other damage.
Old Apr 19, 2008 | 06:54 AM
robair's Avatar
Couldn't you just check the alternator by disconnecting the battery while the car is running and see if the engine keeps running?
Old Apr 19, 2008 | 07:01 PM
jcopin's Avatar
so i had the battery tested..good..
so i bought a alternator there for 285..ugh ..but the good thing is it took all of 20 minutes to remove the old and install the new one.. runs great now lol
Old Apr 19, 2008 | 07:06 PM
theedge67's Avatar
Sure, if you want to burn out all your lights and fry all of your electronics.
Uofmrampage
Aug 2, 2022 02:55 PM
lakersfreak
Jun 13, 2022 12:29 AM
mx5jhb
Sep 30, 2015 04:44 PM
Fred_Garvin
Sep 17, 2015 04:10 PM
MustangGTCS13
Sep 17, 2015 07:38 AM
