Help with how to make it pop more
Old May 1, 2022 | 04:27 PM
noah1957's Avatar
I have a 2006 v6 SlP Power-Flo Axle-Back Exhaust in and it will only pop sometimes when I’m not even trying but when I try it don’t do I could be doing it wrong? It’s a automatic so any tips?
Old May 1, 2022 | 07:11 PM
m05fastbackGT's Avatar
If your referring to the exhaust when the car is decelerating? it will produce either a gurgling type of sound or popping type of sound, depending on what type of exhaust setup your running.. If you happen to be running an X mid-pipe crossover, they usually produce a higher pitched note like a popping type sound on deceleration.. If running an H-pipe mid crossover? these are usually known for producing a deeper pitched, gurgling sound.. If however, your not referring to the exhaust sound during deceleration? then I'm not really certain if we're quite on the same page.. Meanwhile, welcome aboard.
Old May 2, 2022 | 11:02 AM
Bert's Avatar
I also assume you are talking about exhaust sound pops and gurgles . . . you could try forcing a downshift with the shift lever
(but be careful, don't force the car to downshift if you are going too fast for the gear after the downshift, or it may over-rev the engine)
05GT-O.C.D.
V6 Performance Mods
15
Feb 27, 2012 07:48 PM
cfswag
Feb 1, 2012 08:38 AM
Gunna66
Jul 13, 2010 05:36 AM
d*rock
V6 Performance Mods
Jul 13, 2007 07:50 PM
