Help...going to the strip for the 1st time.
Old Aug 1, 2007 | 08:57 PM
scotts05custom's Avatar
I am going to go to the drags strip for the first time next month. I am trying to get my car set-up as best a possible.
I have basic bolt on's... cold air, tune, gears, t-lok, pulley, exhaust, and lca's.
My main question is my tires. I have 275's all the way around right now. I am pretty sure having such big tires in the front will hurt my performance. Right? And if so, how much?
I don't think my stock V6 wheels will fit over my new GT brake calipers...? So where can I get some cheap wheels from that are smaller?
Old Aug 2, 2007 | 07:18 PM
Torch_Vert's Avatar
For a first time trip, I wouldn't sweat that. Just increase the pressure in your front tires to reduce rolling resistance. This is common practice at the strip (45-50psi is generally recommended). You'll find an air station in the pit area at the track for this purpose.
Old Aug 2, 2007 | 09:25 PM
rygenstormlocke's Avatar
Paul is right. Front tire pressure at max, and rear tire pressure at 25 should be ok. Remove your jack and spare tire. Play with your rpms on the launch, start at 1500 rpm and work up from there in 100 rpm increments, perhaps 200 rpm increments.
kponypower
Jun 17, 2020 07:17 AM
RCooke08GT
Feb 19, 2017 03:03 AM
Kalel08
Sep 29, 2015 03:06 PM
GLOCKer
Sep 28, 2015 05:20 PM
