HELP, Which direction to go?
Old May 23, 2008 | 09:01 AM
jdslow300's Avatar
I'm in the army and dont often have the option of playing around with the car or money as I may like so i want to iron things out before i mess with either, I've had it set in my head to get a X-charger when the opportunity arose, and that opportunity arrives next month
I know just enough about cars to get myself in trouble, and looking on here just made me more confused. My stang is a daily driver, no performance mods
so what do i get, what gives you the best bang for your buck? thanks in advance for any help
Old May 23, 2008 | 11:03 AM
MSP's Avatar
MSP
Without a doubt you must get the Powerhouse Turbo with the 7psi wastegate spring entry level kit. Comes in just under $4K.
http://powerhouse411.com/catalog/ind...products_id=52
This will put you at 350RWHP.
This pic is intercooled. But you can start off with the non-intercooled kit, if price is an issue. You can upgrade it later to the intercooled option.
This kit your looking at is solid on the 4.0 to 450RWHP!
Old May 23, 2008 | 04:56 PM
jdslow300's Avatar
and it'll still be a good daily driver? and what else would i have to change on a stock v6 to be good with that much power
Old May 24, 2008 | 08:16 AM
Sniper308's Avatar
If you do a search for "4.0" and "X-Charger," you'll find more information. I don't think you'd be disappointed with the X-Charger at all. Many of us have them on our Mustangs and are quite happy, and our cars are quite "streetable."
Russ
Old May 26, 2008 | 11:17 AM
MSP's Avatar
MSP
You only need to upgrade the rear-end to a 7.5 T-LOK, and add 39lbs injectors and your gold. The stock clutch should be ok with street tires up to 9-10psi. But keep in mind that the SOHC 4.0 from the factory can make enough power to break everything behind the engine, if using drag radials or slicks. So you have to be reasonable.
As long as you don't attempt to run nitrous inside the motor with boost from the turbo, you will be ok for a long time.
You can however spray a 100shot of nitrous onto the surface of the intercooler, and that will increase HP and TQ a great deal.
Old May 30, 2008 | 01:58 PM
GrayPony's Avatar
+1 Sniper308
Old May 30, 2008 | 06:25 PM
ranebowcyxx's Avatar
Pound for pound the turbo will be faster, but the X makes great power down low and has been described as driving a car with a bigger motor. The looks of the X are awesome and you can save money by installing it yourself.
Old Dec 24, 2009 | 08:44 AM
Sniper308's Avatar
I received updates from Dave, two nights ago and last night, to the effect that he expects to have 20 intercooler kits (for making what he's calling the "X-Charger Xtreme" if you already have the X-Charger) ready to ship 01 Feb 10.
Russ
Raynier Leonardo
'10-14 Exterior Modifications
27
Mar 2, 2017 12:08 AM
samjluck
Sep 17, 2015 10:24 PM
Mrmiles1369
Sep 11, 2015 07:23 PM
Sep 8, 2015 10:45 AM
