Fuel Pressure Gauge - What range???
Old Sep 20, 2006 | 04:49 PM
flapjack's Avatar
I'm about to order a Cyberdyne fuel pressure gauge, but I don't know which range to get.
There are two:
0-16 psi
20-100 psi
This of course is for a supercharged V6 4.0L I'm guessing the 0-16 is for carbuerated cars and the 20-100 is for fuel-injected cars.
Old Sep 20, 2006 | 04:55 PM
Torch_Vert's Avatar
There are two:
0-16 psi
20-100 psi
That guess would be correct. You definitely want the higher range gauge.
Old Sep 20, 2006 | 04:59 PM
flapjack's Avatar
Awesome. Thanks for the reply.
Old Sep 20, 2006 | 05:14 PM
Torch_Vert's Avatar
No problem. "normal" pressure is 39lbs if memory serves.
Old Sep 20, 2006 | 05:25 PM
flapjack's Avatar
Hey, would this be ok for an IAT gauge. Cyberdyne's site lists it as an "ambient" air temp gauge. Will it still work??
Old Sep 20, 2006 | 05:42 PM
Torch_Vert's Avatar
I would certainly think so. I don't see your inlet temp ever exceeding 158 degrees
Old Sep 20, 2006 | 06:17 PM
flapjack's Avatar
Sweet. I'm just worried about it plugging into the intake tubing. How would it adapt?
Old Sep 20, 2006 | 06:48 PM
Torch_Vert's Avatar
It depends what the sensor looks like. If it is a simple threaded one just screwing it into an appropriate size hole in the intake tube with a bit of sealer should do. Since it's not under boost, the fitting just needs to be airtight, not mega-strong
Old Sep 20, 2006 | 06:52 PM
flapjack's Avatar
Hehe, I am under boost. 12psi to be exact.
I think this is what the sensor looks like:
NC14GT
Sep 10, 2017 04:47 PM
09-gt/cs
Oct 15, 2015 10:03 AM
