Factory 17's on a V6 question...
Old Sep 21, 2005 | 12:45 PM
austexstang's Avatar
I know the 17 inch factory wheels/tires will fit a V6 BUT will it effect the speedometer? If it does, can the change be corrected?
Old Sep 21, 2005 | 12:49 PM
adrenalin's Avatar
You will need a programmer to change the speedo unless the tires you put on the 17's end up being the same diameter as the stock tires.
Old Sep 21, 2005 | 12:53 PM
yur1279's Avatar
adding to this subject. If you add 17's to a V6, should you also change out the brakes?
Old Sep 21, 2005 | 02:07 PM
Grimlock's Avatar
If you replace your stock 16"s with stock 17"s from a GT, there will be no effect on the speedometer. The total diameter of the two wheel and tire combinations is almost identical. However, if you change to a lower profile tire from stock, then you will affect the speedo. As for the brakes, I don't think a simple change from 16"s to 17"s will make any difference in braking. I didn't notice any.
Old Sep 21, 2005 | 02:26 PM
OK, thanks for all the info....
Old Sep 21, 2005 | 07:09 PM
ex-Galaxie500's Avatar
If you still want to updgrade your brakes, Saleen sells the GT takeoffs
Old Sep 22, 2005 | 09:16 AM
xxkazp3rxx's Avatar
I put 255/50/17 tires on my v6, and I think they said it would change to speedometer by .1 mph, haha. I know Discounttiredirect.com has a calculator somewhere on thier website, search previous posts, I know it's on there.
Old Sep 22, 2005 | 11:24 AM
Zodiac's Avatar
Mmm whenever I upgrade the wheels and tires Im just gonna go ahead and buy the take off breaks.. heck, might as well right?
To answer your question, the GT Take offs wont affect your speedo enough to have to have it recalced.
Old Sep 22, 2005 | 01:54 PM
Just won a set on ebay, sent the check out today
Road_Runner
Sep 2, 2024 04:46 PM
RCooke08GT
Feb 19, 2017 03:03 AM
Feb 10, 2017 07:12 PM
Fred_Garvin
Sep 17, 2015 04:10 PM
Sep 10, 2015 12:44 PM
