engine code p174
Old Feb 9, 2015 | 04:52 PM
silverstang417's Avatar
engine code p174
Today my check engine light came on it said p174 system to lean bank 2 does anyone no wat that means
Old Feb 9, 2015 | 05:01 PM
Possible solutions include: In the vast majority of cases, simply cleaning the MAF sensor does the trick. Spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling Inspect all vacuum and PCV hoses, replace if necessary Check for a dirty fuel filter and proper fuel pressure
copy and pasted from the net /\ /\
basically its lacking fuel or getting to much air. Or mas air flow sensor is dirty.
How many miles are on it and what year is it?
Old Feb 9, 2015 | 05:05 PM
It has 137xxx 07 4.0
Old Feb 9, 2015 | 05:55 PM
Now when u start the car it dies unless u give it a lil gas then its fine
Old Feb 10, 2015 | 12:11 AM
GottaHaveIt's Avatar
almost sounds like a problem I had after cleaning throttle body , MAF sensor testing each injector Wirth battery suringe test & still nothing turned out to be the fuel pump pickup screen was clogged up with all the crap that comes with our gas.
I waited until I got low fuel disconnected fuel relay then removed my fuel pump cleaned it up & walk a runs sweet even gained better miles or here about 100 kilometers per tank.
Attached Thumbnails engine code p174-20150208_143702.jpg   engine code p174-20150208_143828.jpg   engine code p174-20150208_145303.jpg
Old Feb 10, 2015 | 12:14 AM
and just this June July 2014 I flushed my fuel tank out yet as you can see how much came back , in with cleaning the throttle body I got an oil seperator and that alone was a huge help in keeping oil out of the intake.
Old Feb 10, 2015 | 05:42 AM
SpectreH's Avatar
I think oil separators are a must-have and are easy to install. I have a Moroso unit on my car.
Attached Thumbnails engine code p174-168372d1423332944-top-down-cruise-today-georgia-engine.jpg
Old Feb 10, 2015 | 09:03 AM
How much do those oil separators usually run
Old Feb 10, 2015 | 11:36 AM
I don't think an oil separate will fix your issue.
Old Feb 10, 2015 | 12:04 PM
Jazzman442's Avatar
But keep in mind it is an error code. It does not mean that it is really running lean Meaning a O2 Sensor could be off or another sensor giving the computer an incorrect reading indicating it is running lean. I have seen this many times and give an error of Bank# lean. Have you connected a analyzer and looked at the live data?
Old Feb 10, 2015 | 12:08 PM
SpectreH's Avatar
I seem to recall $80...give or take. It and the hood struts were my first mod.
Old Feb 10, 2015 | 07:35 PM
Come to find out that it was an 02 sensor that went out on me
Old Feb 10, 2015 | 08:40 PM
I was thinking that but usually you don't read that unless exhaust work was done. But then again, 137k...
Old Feb 10, 2015 | 08:53 PM
Jazzman442's Avatar
CD I have seen one bad tank of gas take out an O2 Sensor. Wasn't the First Trackey blowing them out too? Also I think I have read that putting on a CAI with out the reducer will give the same code. Computers Go to Love Them!!
Old Feb 10, 2015 | 09:21 PM
Interesting. I hadn't seen those posts.
I just read an article on top fuel and was surprised they didn't use O2's on the headers, but rather an 'exhaust gas temperature' sensor. If its not burning hot and equal, they know something is off.
Old Feb 11, 2015 | 09:04 AM
I was just told that the 87 octane tune I put on my car plus my true duel exhaust may have caused my 02 sensor to go out
Old Feb 11, 2015 | 09:05 AM
Plus I just had another code go off it was a p0300 which said random misfire
Old Feb 11, 2015 | 11:08 AM
Jazzman442's Avatar
Was is there any Mods? Was anything tuned up? Picture of the engine bay?
Old Feb 11, 2015 | 11:43 AM
All I've done I put a cold air intake on it
Old Feb 11, 2015 | 12:14 PM
Which cold air intake did you install? I'll bet its one that needs a tune. That would make sense more air but no adjustment for more fuel to match
